jarance;326964 said:
i'm try do'it the procedure...
but still failure....
i'm try 5 to 10 times but still failure...
maybe becoz my digital meter not functional too.....
how come...
may car make me stress....
erk help...
Oop. Try the procedure on my car and it also don't work. The correct procedure is as follow:-
1. In Stop position, press the odometer reset push button and keep holding it down. Turn the ignition key to "Accessory Position" i.e. from "stop" to "1st position"
2. You see all the oil lamp, etc start to light up. After a few seconds, all the analog meter will swing to maximum position. (tacho, speed, fuel and temperature).
note; you can release the reset push button after the light start to light up.
Use the above test to check the instrument cluster function.
Note : In Stop position, when you press the odometer reset meter, it will display the total mileage and trip mileage.
Stop - engine off
1st position - radio on
2nd postion - display and diagnostic start
3rd position - engine cranking
