Will this headlight adjuster works?
RM125 is expensive unless it for i pair headlamps. I have done many it will only cost RM500 for both plust the adjusters. 3 hours job. Pm me if you wan to change yours. Yes thats the right one
kokwei9035;514502 said:
bro bmw7833,
mind to advice as mine's adjuster already damaged. thanks. :wink:
Just follow what you get from the net, then ok liao.
bimmer73 offers the different way which he able to replace the adjuster without open the lens..That's magic and i still curious how he did it. Anyway that's his ability, so RM500 is reasonable..:rock:
What do you mean by specification. If you meant the headlamp it's for the face lifted model with hella headlamps for E39s. with or without Xenon Hids
skinhead;515631 said:
on my e39, i just use zip ties to adjust the headlight level. 5 min job :rock:
A total different for the light distance after u replace the adjuster.
Cable tie only help u to prevent your projector wobbling.
Zip ties get s brittle and breaks du to heat. Change adjusters cost RM 500.00 no headache for the next few years or at least until it breaks again and god knows when it will break.
kokwei9035;517142 said:
helo bro...how much for it??when u coming back to Penang(Northern part) again?
Yea! I am also interested if you are coming to Penang, Bimmer73.
