haywire;652055 said:Eibach 'ARB' is Anti-Roll Bar, not a spring bro.
oic... hahahah. me newbie la bro haywire...anyway thanks for the explaination.
haywire;651995 said:I've been told the ori M-sport II suspension on an E39 is actually Sachs Super Touring, I have seen the label on my ori one and it does say Sachs. I'm replacing mine with the Super Touring for all 4 sides.
herbert;651979 said:rg470,
I installed Eibach ARB for my e39 for RM 2,400 c/w installation at Hakamotor, Batu Caves Industrial Park. Believe for e46 same price as e39. As for pro-kit, about RM 1,300.
Loh,
Since you are traveling quite a lot on highway, install Eibach ARB and you would feel a world of difference in terms of high speed stability and taking corners.
lwloh;652111 said:Herbert, what is the size of the ARB u have got? Is that the replacement for stabiliser bar for both front and rear? i have check the size of the M-sports stabiliser bars are 24mm dia. for front and 15mm for rear.
bimmerholic;652110 said:What's the damage?
herbert;652260 said:Loh,
Msports ori ARB is 24 mm front and 15 mm rear whereas Eibach is 27 mm and 18 mm respectively. A 3 mm (front & rear) make lots of difference. A fellow OM recently replaced his e39 M5 ori ARB (27 mm front & 15 or 18 mm rear) with Eibach ARB 28 mm front (can't remember what's the rear ... mm). According to him, the 1 mm different is very significant in terms of ride stability.
As for ride harshness, nothing to do with Eibach ARB. Ride harshness will be determine by your type of absorbers.
hakim_radzuan;652289 said:damn this is so racun..hehee :thefinger:
herbert;652452 said:Skarl,
To answer your questions, you can obtain more from Eibach website here. http://performance-suspension.eibach.de/cms/products_products_stabilizer_bars_anti_roll_kit
Eibach ARB is manufactured from cold-formed, high-strength aircraft-grade steel for precision performance, and finished with a longlasting red powder coat finish.
As for Ultra Racing (local made), I really don't have much info other than what is published in their website and advertisment in car magazine.
End of the day, comparision boils down to reputation, research & development, quality and material used.
irdanlz84;653558 said:how is it differ with h&r arb bro?
feisaldzul;647694 said:dont waste your time looking for Sachs Advantage.
bloody expensive and almost impossible to find in Malaysia and Singapore.
Sachs Touring is yr OEM replacement for your stock absorbers.
Its not meant to be used with lowered springs. Can use but be prepared for it to die soon.
Bilstein and Koni are more easily available but Singapore is so much cheaper.
irdanlz84;647213 said:bro,
I normally bought bilstein b8 in hup shun sunway (big falken sign board, located in front of used car, same row with JFA exhaust).
Always got stock, no need deposit. Lousy alignment work. For alignment you can go to MPS auto or Shah Alam Tyres. Expensive but worth it.
For Sach Advantage try search Ebay. No idea how to get in Malaysia.
haywire;666490 said:Turns out I got the front Sachs Advantage, and rear Boge Turbo (same thing, different label) afterall, which is the exact replacement for my M-Sports II suspension. The Sachs Super Touring is actually replacement for normal/non-sport (SE) E39s.
GBP532 (about RM2650) for all four absorbers. Sent from UK to here using my friend's container, so no tax.
Installed the front ones last Saturday, good performance and surprised the guys at Bomin with its performance. No time to install the rears yet, perhaps after raya.
lwloh;666688 said:RM 2650 is cheap for sach advangate. i ask ZF quote 4k+. tell us how the ride is. I am quite satisfied with my softer ride now. not so bumpy compared to the B8. go over malaysian road, much comfy. But cornering time.. hmm cannot compare la to B8. Saving up for ARB..
