python_dev;243888 said:
most BMW's as mentioned in other parts of the forum are factory tuned for 87 Octaine Most of the petrols here are 92 or better, so depending on the tuning of the car (and no 2 cars ever the same) can vary with which ever fuel you use... Since I work with shell I have a tendency to use shell (Got discount one)
so at the end of the day, we will all find what is right for our car by a bit of playing around.
P.S same goes with engine oils also
As mentioned earlier, BMWs are factory tuned for 87 octane only apply to (R+M)/2 method. Malaysia use RON method, which RON97 approx same as 92OCTANE
If you look at your user manual, malaysia BMW recommend minimum 95RON.
python_dev;243984 said:
Regular is a 92 octaine where as V-Power is a 97 Octaine
Yes, V-power is 97RON. Which mean is same as Petronas PRIMAX , Caltex Ulimate(gold?), & Mobil F1.
That is the reason why I boycott Shell gas because same RON but alot more $.
Octain Level relate to how well fuel burns, the higher octaine always means better engine burn and less carbon, as well as gives more power to the engine through better efficiency.
No! Higher octane fuel DOES NOT necessary mean fuel burns better.
You need a better tuning, with higher compression ratio & advanced timing to utilize the higher octane.
If your car only require 91RON, and it does advance your timing base on your fuel selection, pouring anything higher then 91RON is just SILLY waste of gas and money.
main difference in the different fuel companies is the filtering process and the amount and type of impurities which lower the octaine level, in some cases these can do more damage to an engine then most things.
Disagree. The main different between fuel companies in their fuel is their additive in the fuel.
Lower octane gas does NOT have more impurities.
LCP;243993 said:
wan520i, RM should be RON... maybe the Germans says it differently... In this country there's only two grades of petrol, the 92 RON "regular" and 97 RON "premium"... Even Shell V-Power is rated at 97 RON, officially...
Yes, Shell V-power is 97RON. Now, why pay more?
ess530i;340649 said:
just changed from v-power to primax today...the only difference i feel is that i now have more money to spend
i think v-power will only make noticeable difference in ultra-high performance cars like ferraris, porsches & turbocharged cars
Because most of these car has sensor to detect fuel quality(octane rating actually). Like the new Mazda6, it will advance timing until it sense a light knocking. So, if you pour in higher octane fuel, it will utilize higher octane advantage.
Like XXX mentioned, pour 50:50 mix of 92RON & 97RON yield a "better performance".
It make sense. By doing so, the fuel octane in the gas tank is about 95RON.
Most malaysia's BMW is tune to run 95RON. That's why you get better performance.
If the car is design to run in 91RON, Honda Accord for example, if you pour 97RON, you get less HP, less torque, more carbon deposit, and in the end, you end up with higher repair cost.
