Julian, i have been following your thread and what you are doing is good to increase your milage and fuel comsumption, but you are not doing enough...
My V8 3 liter gives me 530km to a RM138.00 full tank.
To get there, you will need to do this:
1. Tyres, must be good condition, correct tyre pressure and use Michellin tyres with 'X' marking, gives you 6% in fuel savings.
2. aligment of tyres better have less tow in, use zero toe, better rolling resistance.
3. Engine, make sure proper oil is used,
4. All hoses and make sure no air leak, intake hose, breather hose good.
5. Throttle body clean and crankcase return hose free from sludge.
6. Valve cover and dip stick no oil leak.
7. Service your MAF or AFM with the cleaner form CRC. adds better hp and nice idle.
8. Service your injectors, balance it and do a test leak.
9. make sure your fuel regulater is working plus the vacum hose is good.
10. TPS at the throttle body working.
11. Fuel vapor purge valve is working, if not, can cause rough idle and loss of power.
12. All rib/v-belts working and alternator giving good output charge.
13. battery is good condition and reads 14.2volts when engine on.
14. O2 sensors must be good too and proper readinga achieved.
15. Running gearbox and rear diff with good oil, new at 40k kms is good.
16. Your spark plug gap is good and even burn.
17. check your plug coils also is good ohm rating. check also the rubber boot.weak boot, can cause arching, misfiring.
hopefully this will make your FC better.
