julianpang
- Jun 7, 2007
- 219
Just to share this with fellow brothers and sisters hereMy car is a E34 525i (M50B25) manufactured in 1994 with automatic 4 speed GM gearbox.I had the car since October 2011. Since day 1, I have been getting a range of 400~420km on a full tank ($130 RON95). Thats is pure PJ/KL city driving. I thought this was bad and I thought of improving it. I have seen friend's 525i getting about 450~480km per tank.So I narrowed down a few things to check on my car.1. O2 sensor possibly time to change.2. Possible stuck exhaust back box3. Might be gearbox since i noticed I have very mild slippage between 1st and 2nd. And also from 2nd to 3rd.What I discovered last week1. My car (local AB spec) doesnt not come with o2 sensor. There were no o2 sensor lubang at all on the whole exhaust system.2. I plugged in the OBD to get the o2 reading and I get constant 0.4v reading set by my car's ECU. If o2 sensor is there, the reading will flutuate. 3. My car does not come with a catalytic converter.4. I cut open my back box and discovered this. back box collapsed and condemned (refer to pic below)
What have I done after I discovered the above1. Bought and install new o2 sensor.
2. Bought a 2nd hand back box from chop shop. You got to shake it and make sure you dont hear loose bits in the box before you buy it.The end resultsAfter the above, I pump full tank to test the consumption. I have not finish my tank yet.Previously, when my car hit 50km mark, the fuel needle will move down slightly. So far with this tank, I have done 70km and the needle is still stuck at full mark.I will update once the fuel level go down or when I finish the tank. In terms of performance, low end torque feels about the same. However, I can feel improvement mid range to high range. Gearbox will be 6 months down the road since my mechanic told me to use until it condemn.
