Hey Guys, We're looking for a BMW F30 328i (I4-turbo), to install the complete aFePower package. We will be offering a 40% discount on all parts for the and the full cost will be just $3,430sgd. This pricing is inclusive of tax, full installation and a dyno run. This pricing is only offered to ONE car. so hurry and contact us now. The full list of parts to be included are:aFe Power Magnum Force Stage 2 Cold Air Intake (w/ Dynamic Air Scoop)This all new Momentum Sealed Intake System produced 10hp and 14lbs. x ft. torque and outflows the factory intake by 42%. This system uses a PRO DRY S progressive mesh three layer synthetic "oil free" filter for maximum airflow and convenience. Also included is a unique, patent pending sealed airbox design to increase airflow using the factory air ram air scoop for maximum torque in all weather situations.aFe Power Scorcher ModulePut up to 52hp and 60lbs. x ft. torque! The aFe Power SCORCHER Module is designed to alter the pressure sensor signals to increase turbo boost to an optimum level throughout the entire RPM range. The result is a harmonious balance between power, throttle response and drivability. This simple and safe plug and play module adds instant power by altering pressure sensor signals to increase boost to an optimum level throughout the entire RPM range. Scorcher modules are 100% tested, have output protection on all signals and are built to a 0.1% tolerance on components in critical areas. Signal filtering is used for a smooth response. These modules work great on vehicles in stock trim but are optimized to maximum performance with use of aFe Power performance parts (intakes, filters, exhaust, etc.).aFe Power DownpipeThis aFe Power Cat-Delete Down Pipe eliminates the catalytic converter for maximum exhaust flow for the popular 2012 BMW 328i with the N20 turbo motor. In recent dyno testing, this race pipe produced 13hp and 29lbs. x ft. torque and outflowed the factory down pipe by 287%. This system uses a 4" diameter tube and progressively tapers to increase exhaust velocity and usable torque. This high performance race pipe is constructed out of lightweight, TIG-welded 4" stainless steel.aFe Power Mach Force XP Catback Exhaust (w/ Black Tips)This new MACH Force XP exhaust system is for the 2012 BMW 328i F30 with the new N20 2.0L turbo engine. In recent testing this system produced 12 horsepower and 17 lbs. x ft. of torque. This exhaust system is constructed from 3.0” mandrel bent stainless steel and is MIG-welded. The system uses a high flow 18" transverse muffler with 3" diameter tubing which improves performance across the power band while maintaining a great tone. To finish off this exhaust are dual double wall resonated angle cut gloss black 304 stainless steel tips. The factory actuator drive is retained with the aFe exhaust so that a check engine light does not occur. This exhaust uses all factory hanger locations for a hassle free installation.FOR FULL DETAILS AND PRICING, VISIT - http://dme.com.sg/webshop/index.php?cPath=361_362CALL/TXT/WHATSAPP - (+65) 9722-7089BLACKBERRY MSG - 28CFBB5B
[video=youtube;uB12WToyxXk]http-~~-//www.youtube.com/watch?feature=player_embedded&v=uB12WToyxXk[/video]
