http://www.f30post.com/forums/showthread.php?t=709829From the Bimmerpost article... Drrooolllll.. just plug and play additional 56 ponies. Anyone in Malaysia installing this? Hartge Engine Performance Upgrade - F30 335i F10 535i F25 X3 35i (N55 Engine)HP gain = 56 hpTrq gain = 59 ft-lbsThe Hartge 'Engine Conversion' is a bespoke tuning module that plugs in ahead of the engine computer on the wiring harness. It has factory-style plugs to connect in-line with the water temp sensor, fuel rail pressure, turbo boost pressure sensors, turbo wastegate valve, intake camshaft sensor, 12V power and ground. The module then sends a modified signal to the engine computer allowing it to increase boost by varying amounts depending on load, engine speed, and other factors.All of the factory safeguards remain in place, including overload protection, warm-up protocols, and the engine tuning is unchanged below 70% throttle to preserve all factory driveability and emissions certification*. One of the key advantages of this type of 'piggyback' system is that it is unaffected by factory BMW updates and service. If BMW updates the computer software to fix any small bugs or issues, the Hartge performance upgrade is not lost or overwritten. This is key on a new model like the F30 because BMW is constantly releasing small software updates. All of the factory diagnostics and service access is retained.This item fits the following BMWs:2012+ F30 BMW 335i - Sedan2011+ F10 BMw 535i 535i xDrive2011+ F25 BMW X3 xDrive35i
