I can't resist...here it goes: -
Cosmetics
1. Facelift lights and fenders. If you dont wanna go through that, aftermarket angle eyes from WRC
2. Rims are awesome, classic on the E38. You need to drop the ride a little, suggest Titan set up with H&R springs or keep stock standard with Blistein and H&R springs
3. Tint job if not already there
4. I would go with a fresh quote of paint. Seeing your interior is black, I would go for something striking in shades of green, orange or red. I would also black out the chrome to match the dark interior
5. Before u do item 4, wait for Unker's AC kit......
6. Interior looks tidy, but I would refresh with a touch up job if needed e.g. A, B and C pillars, roof, side steps
7. New set of custom made interior floor carpets, not the master carpet
ICE
1. Eventually, the CD player will kong if not already so, touch wood. If planning an ICE upgrade, change head unit (single DIN), speakers are already awesome so no need to change. Add a sub, best if active (not too much base). Reasonable budget for good performance
Engine
1. Change Vanos seal - Herbert is your man
2. Check all sensors, replace as necessary
3. Compression test and O2 sensor test
4. Cooling system test, do when changing Vanos seal
5. Undercarriage inspection i.e. arms, bushes, joints
6. Check all seals especially flywheel
7. Transmission test, flush and prep
I think enough for now.......hehehehehehe
