Silver humble E36
Bro Dragman, well done man. Nice to meet you man.
Bila mau kena teh tarik Bro, just call me... I'll be there.
Good stuff dragman. You're truly a UDM enthusiast. I think it's a great idea to share your experience with your ride visually. Damn, make me reminisce about my ex-E36....it's a great car:top:.
good job, me also changed all the rubber stuf this year.. now need to check all hoses!! kedai mana, dragman?
Bro Sach, itu kedai at jalan Kuchai Lama Ah Lai shop, I think you knew the place....
Daredevil,
Tq bro for your support, what is important to me is good handling and safety when drive fast.... and feel comfortable when drive either fast or slow...
AZAM,
no problem... tq to you too for belanja milo tarik.... next time i blanja u pulak...
Bro sach,
yess... like azam said the shop at jalan kuchai lama ... many extra's that area.. accessori shop pun ada mamak pun ada and... urut2 pun adaaa.... heheheh...
Here is the list and price what i've done to my second wife...
Middle Exhaust Mounting 2 x RM16
Welding exhaust crack RM40
Front lower arm bush 2 x RM95
Front lower arm ball joint (S) 2 x RM85
Front lower arm ball joint (L) 2 x RM100
Engine mounting 2 x RM170
Valve cover gasket 1 set RM140
Valve cover seal 15 x RM9
1 pc Oil filter seal RM35
Rear axle bush (S) 2 x RM85
Rear axle bush (L) 1 x RM95
Stereng tierod 2 x RM165
Front sway bar link 2 x RM95
Front sway bar bush 2 x RM65
G.box mounting (S) 2 x RM45
Axle oil RM38
Topup engine oil revenol 1 liter RM24
Front tire Alignment RM20
Labor charge for pump bushing at machine shop 9 x RM20
Labor charge for all installation RM450
Tierod, sway bar link and most of the bushing are made lemforder.
Greats
Bro Dragman, high pay aar... like Metallica song "no pain no gain"
and BMW means: Banyak Makan Wang... huhuh.... :wink:
Total nearly 3k huhuhu.... habis bonus aku bulan nie....huhuhu... you are right bro.. BMW = BAYANK MAKAN WANG... but its one time in 10 years maybe, hopefully huhuhu ... maklum lah keta tua, over 10 years car...
Hai Dragman, i'm newbie here, just registered into this great forum and zero knowledge
about BMW car. I've read your thread, need to know what are the different for E36
car for the 318, 321 and 328, is it because of the speed? Some stated as M3.
Thank you Sir.
GokuSan,
welcome to BMWClub.... below is the list of engine spec for most e36 series...
M40 - Straight 4 cylinder SOHC 8V. Replaced the M10. 1987-1993. 81kg 178lbs
Used in post 87 E30 316i/318i, E34 518i, Pre 93 E36 316i
1.6 (102bhp), 1.8 (122bhp)
M42 - Straight 4 cylinder DOHC 16V. 1989-1996. 100kg 220lbs
Used in E30 and E36 318is, Z3
1.8 (138-142bhp)
M43 - Straight 4 SOHC 8V. 1993-1998. 83kg 183lbs
Used in post-93 E36 316i/318i, E34/39 518i.
1.6 (102bhp), 1.8 (115bhp)
M43TU - Straight 4 SOHC 8V. 1998 on. 83kg 183lbs
Used in E46 318i
1.9 (118bhp)
M44 - Straight 4 DOHC 16V. 1996 on. 102kg 225lbs
Used in E36 318iS, Z3
1.9 (142-150bhp)
M50/M50TU - Straight 6 DOHC 24V/Straight 6 DOHC 24V with Single VANOS. 1989-1998. 136kg 299lbs
Used in E36 320i/325i, E34/39 520i/525i, Variation of this was used in the Early US E36 M3
2.0 (150bhp), 2.5 (192bhp), 3.0 (240bhp) Sometimes referred to as S50US. Engine shares more common parts with M50 than Euro S50, but is a motorsport engine.
M52/M52TU - Straight 6 DOHC 24V with Single VANOS/Straight 6 DOHC 24V with Double VANOS. 1996-1999. Iron Block in US, Alloy Block in Europe. 118kg 260lbs (alloy) 140kg 308lbs
Used in E39 520i/523i/528i, E36 323i/328i, E38 728i, Variation of this was used in late US E36 M3.
2.0 (150bhp), 2.5 (170bhp), 2.8 (193bhp), 3.2 (240bhp) Sometimes referred to as S52US. Engine shares more common parts with M52 than Euro S50, but is a motorsport engine.
Hai Dragman, thank you for the high-lighten info. Now, I knows a bit what are those 3 series meant.
Thank you Sir, appreciated it.
