[Sharing] Angel+Demon Eyes & Morimoto H1 Mini Project
Bro AidilJ, err that Low beam shroud is nice... where u get them? i want to order 1 more set cause i want to paint the XENON word in other color :p
BTW i think you mount the shroub in reverse??
Cause the "Xenon" facing outwards?
xcrave, the low beam shroud came with the projector bowl assembly I bought. I think that is the original shroud, not replica. The shroud is mounted correct, facing in.
I think it was suppose to face out... well maybe i was confused on these picture ...???
:p
The EVO X picture you attach is a retrofit using OEM E46 shroud, during the work they rotate the shroud so the wording face outside. See here :
http://www.hidplanet.com/forums/sho...fit-FX-Rs-OEM-E46-shrouds-CCFL-Halos-Red-LEDs
Original E46 shroud have the word facing inside. See here :
http://www.hidplanet.com/forums/showthread.php?36935-BMW-330-upgrading-light-performance
http://www.hidplanet.com/forums/showthread.php?39580-BMW-e46-quad-retrofit
You can swap the shroud from left to right headlight to get the wording to face outside but I think a minor cut is needed as there is a ridge unique to each side's shroud
Well i still think its nicer when it face outside more over when you custom paint it red (like what i will on the XENON wording :p)
