ALBundy
Founding Member
- Dec 4, 2004
- 11,610
- 38
turbology;463488 said:I thought you are not suppose to stay at constant RPM when running in engine ?
Refer back to my quote, a 9.0:1 engine with bad tune are as bad, or worse, then a 11.0:1 car. Running a lower CR, with give you more BUFFER for error, but is not going to solve the knock. When the engine detect knock, it will retard. But when you are the lower map of "retard", and still having knock, you are deadend.
With your constant knocking case, I strong believe the tune is off. Or, the air intake temperature is very high (before the turbo). Or the intercooler is not doing enough.
Does running Toluene mix help ? How about spray some water, or even ICE, on intercooler to see if knock goes away?
Previous youtube video, i remember that brand is a Wideband O2. Just to be sure, is it ?
You can just throw away the narrowband O2 sensor.
Besides having a AFR as a guage for "safety measure", have you consider the EGT (exhaust gas temperature) guage ? Is part of the tunning "factor" as well, besides the Lambha O2 sensor.
The spark plugs tip looks just fine, matching with the reading of the AFR. If is running really lean, the tips will be very clean with rainbow color.
For what I know, and came across, running the oil cooler will help but is not going to solve your problem.
Your piston failure is definately detonation, and my theory, the root cause is heat. Or the particular gas station is not honest about thier V-power.
Cheers.
p/s: psss... check your PM![]()
The biggest challenge in installing forced induction units is getting the tune right, more so in a tropical country like Malaysia, where humidity is high and ambient temperature is high.
Lowering the compression ratio to 9.0:1 may solve the problem, but you will lose out on the response and ultimately the hp gain. There are some sites, that could generate some estimated hp calculation given the compression ratio + turbine pressure = Effective Compression = Engine HP.
The current trend is to use forced induction with high compression engines, like the Golf GTi, BMW 335i and etc. High compression engines with forced induction will generate a lot more low end torque with little lag. The 335i runs with 10.5 compression ratio with a 0.8 bar (about 11.8 psi)turbo boost.
It is even more crucial (in my opinion) to run higher compression in a supercharger setup, given the fact that the supercharger will ONLY generate maximum boost at the redline unlike a turbocharger. In other words, at low rpm with the lower compression engine, you could worse off than running NA, and only gain torque possibly at the midrange + top end.
Hope your engine will run well this time around, it has been sitting at Fatty's shop for ages
Cheers
