Upgrade to M54B30 or stroker kit way?
Herbert;848163 said:
zidee,
In March 2013, I put in a 3 litre stroker kit for e39 M54B25 plus a complete overhaul of the engine. Items for the 3 litre stroker kit :-
1. 6 x M54B30 piston c/w connecting rod
2. 6 x M54B30 fuel injector
3. 2 x M54B30 camshaft
4. 1 x M54B30 crankshaft
5. 1 x ZF5HP19 - 3.0 litre torque converter
You do not need to change the ECU and instead a re-map will be fine. Call me if you need further info.
i have spare:
psssss.... go manual straight..
tehyw;848863 said:
i have spare:
Thanks. PM me with quote if you don't mind
- - - Updated - - -
tehyw;848863 said:
i have spare:
Any stroker kit still available ? Can the M54 kits used in the M52 ?
Should be able to. I know people have used M54 stroker kit on M50. M54 is an evolution from M52, a much closer relative.
unstopables_7 said:
Is it still available? Pm me pls
Sent from my GT-N7100 using Tapatalk
I've got a 3 litre stroker kit that'll take the M50TU to US M3 specs and a little bit more. crank, rods, pistons, cams, 3.5 maf and accompanying AA tune for 3.5 maf+intake+exhaust. I've got the same AA tune on my car currently. PM me if interested.
