fabianyee
Founding Member
- Nov 25, 2004
- 8,860
- 38
As I've mentioned before somewhere that I replaced my Bilstein Black with Titan tuned front absorbers and found that the front sits lower than before and the Eibach springs were almost fully compressed. It tends to be a bit 'crashy' as going over undulation at speed would fully compress the springs and cause a thud. After few weeks of careful driving over rough roads, I decided to fit back the Bilsteins. From what I measured, observed, checked, bla bla bla. I find that the fault is not the Titan absorbers, it's the eibach springs. it's too soft. With the Titan absorber off the car, I pressed the strut to feel the bound and rebound rate for both the Titan and Bilstein. I found that the Titan is a lot stiffer than the Bilstein. But why is the front sitting lower than the Bilstein and 'crashy'? That is because of the bumpstop/dampener... To verify that, I fit back the bilsteins with the bumpstop in place and lowered te car back on the ground. The front is sitting higher with good clearance gap between the spring coils. But when I tried to move the bumpstop using a screwdriver, it doesn't move. The front is resting on the bumpstop when it's lowered, especially with the Eibachs. That shows that the bumpstop is actually acting as spring.That's my observation. What does that all mean? Think about it. Is it good? No good? Wat's better? Maybe u can tell me more....
