azam318
- Apr 23, 2007
- 1,687
Lionel_Koh;407911 said:Buy a new one lah ...hahhahahhahahha
-------------Cabutz------------------
Hahaha... as long as its still can be use, DIY first lar... no money lar to buy...
Russie;407923 said:Good sharing azam318. If the inner glass of the foglight is dusty and with some moss forming, you could actually clean it up. Here's what I did to my old pair of foglights:-
1) Mix some very mild dish cleaner (eg. sunlight brand dish cleaner) and pour it into the inner of the foglight thru the socket hole.
2) Cover up the socket hole and give it a shake (yeah, shake it baby). U would notice that this process will remove some dusty/ oily surface.
3) Then rinse the inner part with clean water thoroughly (but not for too long as u may risk removing the reflective chrome surface).
4) Next, put it under hot sun to naturally dry the foglight, inside out.
5) Seal the gap with silicone sealant (one have to be able to take sourish smell during this process). To get best result, use bare finger to smoothen the edge.
6) Let it dry for at least 6 hours before installing the foglight back.
Tip: U should adjust the socket position facing down as this would prevent water from going in thru socket gap.
Goodluck
harry811;441212 said:aja lah aku wat ring lamp save kos takyah ly lampu.
jarance;441609 said:The leak seem to come from the front.. i.e from the torque converter.. Look like the oil seal for hydraulic pump is gone..
You need to change the whole pump if it gone. Go for new rather than second hand.
azam318;441612 said:Jarance, thanks for the advice. Do you know how much does it cost for the above said?
initialM;442685 said:Bro,
R u goin to overhaul yr gbox? If yes, my advice don't. I believe yrs is M43 engine rite?
Since overhaul the gbox will cost u few thousand might as well u convert the whole engine & gbox to six potter. U'll thank me in future:listen:
ICEMAN 13;442780 said:and to add on ...time to plonk in a manual box ....with the 6 potterthen can drive harder
wahh initial M you punya racun very the strong lorrrr
