My first mod on my 11 yrs old Babe...
Nice, nice... banyak cunnnn..... Are u using HID for you foglamp what type it is, 4300?
not HID laar , my mech just replace the stock std yellow bulb / light to white
- to match the headlights ..:listen:
OIC... thanks Bro.... :top:
megatniza;381372 said:
bro ,
kasi tambah eye brow , kasi lagi garang sikit !
Bro Megat, do you means eye brow like e60 punya signal aar...? :marchmellow:
Foglamps - HID installed
Just to update for my 2nd mods on the foglamp with the HID installed.
Thanks to Dragman for helping me, guide me to the Ah Lai shop... nice to meet you :top:
Installation done at Ah Lai shop, Jln Kuchai Lama.
I'm feel happy now...he he he :wink:
1) Installation begins
2) HID kits
3) Foglamps installation done
4) Nite vision
Bro, no problem... hohoho.... is it x'mas present for your udm..? baru cun maaa.... :top:
Thanks...
Thanks Bro... its all bcoz of you're poisoning me... he he he... :top:
but actually itchy oledy ....huhuh .... :wink:
My Engine Oil Leaking and unexpected failure...
Hi Guys, fyi, today bring my babe to workshop for some repairing on the engine
oil leaking. The leaking due to the gasket oil and oil rings worn out. Below are the
several pics I would like to posts and share with all forumer here. Unfortunately,
there're unexpected faulty on my babe. Happy viewing.
Car lifted up
Engine underneath pretty bad, mess up everywhere...
Dismantle everythings
After Cleaning
New Gasket
Unexpected failure on both long belt and short belt
New belt
Fixed both belts
Lifted up my car again and my mechanic do the inspection again and found
out another faulty with my car. I'll continue later and will upload more pics
to share with you to tell the sad story. Feel so exhausted, spent the whole
day to accompany my babe in the workshop. To be continue ... :wink:
Unexpected Faulty during inspection...
After done on the engine oil leaking, try to do some minor inspection but
something I'm not expected to my babe on the RL disc brake was cracked.
The mechanic told me as long his do the repairing never seen this kind of
problem. Pls find below are the pics for your viewing. Tq.
RL Disc Brake Crack - Luckily nothing happen to me and my family during
ride on it, before.
Changing parts...
Get the 2nd hand brake disc... save money $$$
The 2nd hand stuffs still in good condition and did the grinding on the both discs.
Actually the effected disc is only my left side and there's no problem on the right
side but my instinct told me better to change it, so I've decided to changed both.
Another parts changed...
Do another inspection on the rear axle and rear absober.
Found out the axle still in good condition, nasib baik he he he...
but the absober and bushing both RL are really in bad condition
and worn out oledy, so kena tukar lo ...
Found out rear bearing for both left and right koyak oledy....
Need to change lo ...
Rear bearing are the most hardly to pull out ...
Another pics...
Rear bearing are the most hardly stuffs to pull out ....
Changed new bearing for both left and right.
Another pics...
After long day for me in the workshop, decided to have sight-seeing around
the area and tends looking for ACC shop. And guess what...?
I ternampak ini kereta ... TOYOTA with M3 bumper ...
Ok jugak, not bad ... huhuh... :wink:
Another good pics
Nearby the shop, I've found e36 babe with two digits number...
Vely vely nice number two digits 36....
Ok...sigh... after the sight-seeing, now back to the work shop to see my babe
Front wheel bad condition...
Feel not really comfort on the steering shaking, even kena lubang kecil pun
or hump, feel shaking the whole body. Before, expected the problem due
to steering rack failure but my mechanic told me, need to do the inspection
first then will decide what's the actual problem. Pls view the pics as shown
as below. Thanks.
M3 front bush worn out
Wallaweiii.... good job bro...:top: the real enthusiast ... hadiah new year for your udm... its time to change bro, everything all the bushing rubbers down there... sure now drive like new car ... and sure poket koyak sket... BMW la kata kan.... huhuhu...
My mechanic did checked on the steering rack and he told me
its still in good condition but the Steering Tie Rod are the most
culprit and that's why the steering in bad condition and need
to change the part.
Bad Tie rod
UDM the best...
Yeap! its really fantastic driving the UDM nowadays, after changed all the culprit bushing rubbers and the worn out parts. All the sounds like keebaabommm disappeared oledy,
now sounds only Dub Dub Dub... too comfort... yeehaaa!
Sigh.... definitely... money gone by the wind ... but the important things is the feel of UDM when we're driving it ..... :top:
