Michelin Pilot Sport 3 Tyre
deep3102;507562 said:
i was quoted RM1060 per piece for PS3, 18 inches...logical ah?
What is your size?
Heng Heng Klang quoted me RM970 for 245/40/18 yesterday.
bmw7833;507751 said:
what is your size?
Heng heng klang quoted me rm970 for 245/40/18 yesterday.
235 40ZR 18 95W extra load can take speeds up to 270kmh....the ride very smooth and silent
Click here to help the kids...http://www.bmwclubmalaysia.com/forums/showthread.php?t=35244
What is your size?
bro, go to glenmarie, stamford tyres...PS3 245/40/18 rm 830 only
maxxsp;506442 said:
235/40R18 is correct i think, even the Alpina Teilekatalog lists this as correct front size for 18s.
for E39 front should be 245/40/18 rear should be 275/35/18...however 265/35/18 still acceptable.
with 235/40/18, your speedo will over read by 1.3%...with 245/40/18 speedo will over read by 0.1%
ramsing;506354 said:
bugger ps3 no size for 255/40/17.
t2...can check with MPS ar if they got the above size for ps3
Sing, for 17", PS3 produce up to 245 only ..... unless Manji bluff me.
Pakcik pakai Michelin Energy saja ... very the satisfied one, heheheee. Higly recommended for heavy machines like us. Other Michelin oso OK but the thread will not last laa. Dont know I'm right or not.
kayzhen911;535477 said:
dudes....
ever tried toyo proxes 235/45/17?
works like magic
costs only 650.
i agreed sometime mid range brand will do n work good .branded is good but price too expensive.
guys....
was told that u might get ps3 cheaper maybe coz its made in thailand or china.
these ps3 might turn hard at 50% usage.
better pay more for japan made ones...
my 2 cts
kayzhen911;535802 said:
guys....
my 2 cts
ALL PS3 235/40/18 is made in thailand.
ALL PS3 225/40/18 made in hungary.
Different sizes are made in different country for michellin. But they claim that the standards are the same. Why they produce like that i have no idea.
Toyo Proxes T1R is good no doubt but wear faster because soft compound grip very good. just like the Toyo Trampio in fact T1r is even softer. And for toyos you need to put higher PSI because tire wall is soft. If you don't put in enough PSI your car will under steer. PSI for front must be 36 for rear 34PSI. I have used Toyo.
guys, which profile should E39 go for 18" 225 45 18 or 225 45 18 ?
please comment
please comment
my fren, both your profiles in question are 225/45/18, so what answer are you planning to get?
FYI, the size is totally wrong and its more than the 3% ruling.
http://www.miata.net/garage/tirecalc.html
please use the above link to determined yourself...
anyway its F 245/40/18 and R 275/35/18 or 265/35/18 is acceptable. (if your rims are staggered)
Bro,
I think for our rear wheel drive cars, rear tyre pressure must be higher than front for better handling and FC also. I'm on 235/45 R17 Hankook S1Evo all round, I am now running 30 front, 35 rear, OK. On full loads, I run 32 front, 37 rear. I can't go lower cause car becomes heavy. I have travelled about 30k km using the tyres, since last year, the wear looks OK and tyre seems to last pretty well. I bought the tyre if I remember correctly for like Rm420/piece, made in Korea. I would say worth it.
One thing I need help to understand, who can calculate and translate that into distance covered? Here is the explanation from the tyre size difference.
E39 standard is 225/55, R16, I use 235/45, R17. The tyre comparison site tells me I am 1.6% too fast. When my speedometer reads 100km/h, I am actually travelling 98.4km/h. So, how do I translate this into kilometer/distance covered? I service my car every 10,000km, does this mean I am actually servicing my car too soon now?
the right size for E39 should be for 18' is 235/40/18 or 235/45/18. 225 not advisable. E39s are heavy. 225s wear is faster and the tire tread will come of after some time. if you are using 225 your tire wall should be higher. 225/45/18 may be can.
