Another option you have is take the rotating assembly (crank, pistons and con rods) from the M54 and stroke your M52 to 3.0L. Of course to optimise you may need to remap your ECU to get the most out of your larger displacement engine.
Yes,
If you are running on M52TU(Double Vanos), you able to swap the complete engine by using back your ori intake manifold & throttle body. Regarding the ECU, can ask any tuner such as Bernard to have a magic touch on it.
There are oredi a few running this set up in M'Y. As I said earlier, forget abt the e throttle. Use back your ori intake with the drive by cable throttle will do.
Hi Bikerz,
Have you upgraded your engine. If you have done, I would like to seek your advise on this. Plan to change my e39 M52B25TU with a M54B25 engine.....
Hi Bikerz,
