tweiboon;607816 said:Have you see the code behind your key ? That code is for you to clone the key actually. If the key you bought same with your original key then i think you can start the engine.
haywire;607844 said:that is not the code, thats the part number i think. from what i gather, the key programmer must copy the code in the original key, and copy it to the new key. not just cutting the key only.
jarance;602013 said:It can be done with a BMW Scanner with a laptop. There is a group buy going on now. Join us if you want.
http://www.bmwclubmalaysia.com/foru...rSoft-diagnostic-software&p=601995#post601995
tweiboon;607944 said:This device can clone the key too, Jarance ? You got the device ?? Can demonstrate how to copy the code to new key or not ?
jarance;607965 said:I know I can read the code but I have not try to write the code as I dont have a sample key.
I have bought a 315Mhz key for USD70 and I will experiment with it.
Sorry, I cannot demonstrate now cos I sold my scanner. Now waiting for the new scanner to come.
Here is a screen shot of the DME to EWS sync code. I have oblige the last 2 digits for security reason.
jarance;608165 said:tweiboon and crazee, how much did you buy the key for and how much did it cost to cut the key.
If I am not not mistaken, all keys have should different ID. If same ID, how does your car know your favorite setting of
the driver seat position, aircon temperature setting and mirror?
btw, I doubt the scanner can reprogram the ID of the key. based on what I read, it required a special tool.
I will know more after I try it.
Alex5522;608104 said:If u need it urgent try the contact the person which i hv posted on thread #12 page 2.
I did mine from him the car can start but can't remote control the door.
tweiboon;608215 said:I bought the key about RM140. The key not coming with new uncut key. It is a used key. And is 315 MHz which not suitable for my car.
tweiboon;608216 said:Then how much he charge you ?
jarance;608236 said:The key is cheap but why are you buying a used key? The pattern is not suitable for your lock. are you planning to transfer
another key to the old key.
Not many people will buy used key unless they want the some part from the old key and they transfer the transponder over.
315 MHz should be correct if I am not mistaken. Can you open your door?
tweiboon;608309 said:ehhhh.............i have try it but not able to open my door. I think my car is use 433 MHz because my key is using Siemen. I saw Siemen key in ebay which is 433 HHz so next round will buy new uncut 433 MHz key
What is the price for clone key device ?If it is cheap then i can clone myself and help ppl to clone free.heheheheheheh
