genozide;847177 said:Noises from the bearing goes louder with speed...on front disc brakes, there is a plate located behind the rotors....it could be the plate is intermittently in contact with your rotor...
Volvos525i;847268 said:You should service the caliper then see if the prob solved..
If the isues here is bajet then not worth we in here tryng to solved it either...
aku ada stereng lori dan bas......kau ada....
Volvos525i;847371 said:Have to do a full suspension check to find the actual prob cone from. ..
Volvos525i;847405 said:Bro where do you stay...
Can bring your car to our mechanic in seri gombak for inspection to trace the actual prob n try to solved it...
genozide;847408 said:X2n,
Should the intermittent noise is associated with the thin metal disc behind the rotor, the probable way forward would be to bend them away from the rotor contact.
Secondly, on your rear brake jam thingy followed by replacement of the pad, you have not solved the real issue which is the brake piston could have been jammed or there is restricted movement leading to uneven wear on the pads.
You may wanna bring your car to a proper mechanic as this is encroaching integrity of the car.
Volvos525i;847424 said:Its awe workshop our regular bmwclub e39 gengs...
Im not promoting but trying to help...
