grinding sound on front right wheel
Noises from the bearing goes louder with speed...on front disc brakes, there is a plate located behind the rotors....it could be the plate is intermittently in contact with your rotor...
so how to rettle this problem? do we have to overhaul the brake caliper?
- - - Updated - - -
went to my mech yesterday, turns out the rear brake was jammed too. we checked the brake pad and saw the pad was worn out uneven. changed the pad but did not service the caliper (budget :p)
this doesnt solve the problem yet. will update this thread
- - - Updated - - -
I wonder who your mechanic is...
If the brake was jam'ed n only replaced the pads, wasn't the problem was the caliper ? Its jam'ed due to the caliper n by not overhauling it, u have still not solved your problem.
- - - Updated - - -
- - - Updated - - -
- - - Updated - - -
You should service the caliper then see if the prob solved..
If the isues here is bajet then not worth we in here tryng to solved it either...
aku ada stereng lori dan bas......kau ada....
Now sound sometimes occur when im into left corner... Pelik la pulak hehehe
- - - Updated - - -
Have to do a full suspension check to find the actual prob cone from. ..
previous owner already changed the suspension, brand new bilstein black... i dunno if there's any defect on it
- - - Updated - - -
Check for any parts touching or make any contect underbody...
hm.. i do hear a knocking sound sometimes, when i hit the clutch. i duno whether that also one of the possibility...
sounds like 'ketak ketak ketak...'
- - - Updated - - -
Bro where do you stay...
Can bring your car to our mechanic in seri gombak for inspection to trace the actual prob n try to solved it...
X2n,
Should the intermittent noise is associated with the thin metal disc behind the rotor, the probable way forward would be to bend them away from the rotor contact.
Secondly, on your rear brake jam thingy followed by replacement of the pad, you have not solved the real issue which is the brake piston could have been jammed or there is restricted movement leading to uneven wear on the pads.
You may wanna bring your car to a proper mechanic as this is encroaching integrity of the car.
i think i may have to leave the car for the mech to inspect it himself. seri gombak? is it vasu's workshop?
- - - Updated - - -
genozide;847408 said:
X2n,
thanks man.
i did told my mech about it and he also agree. but since i didnt have the right budget, i decided to hold it till next month to repair the brake piston.
- - - Updated - - -
X2n,
thanks man.
Its awe workshop our regular bmwclub e39 gengs...
Im not promoting but trying to help...
Its ok man all replies in this thread are appreciated. I think my car need close attention from mech. Currently i dont have a workshop that can do that.
problem solved!
apparently, there's a screw/nut in the brake caliper (front driver's side) went bent. went to optimum yesterday, and kebetulan the sound went crazy as one of the mech drove my car. cost me rm80 only. all praise to God ^_^
special thanks for all bmwclub members that helped me ^_^
driving is good again aaaahhhhhhhhhhhhhhhhhhhhhhhhhhhhhh :D
well good to hear its solved...
that is why in the 1st place propsed a complete brake system check...
