Fluids for M engines
ssmann
Friends,I am starting this thread as a base to gather/share info on what fluids should be introduced into a M ride. Specifically mine is a S50B30 with a 5 speed manual gearbox and LSD. 1. Engine oilThere is significant debate out there around engine oils for M engines. In my assessment this is partly the result of BMW choosing Castrol (owned by BP) as their official lubricants partner, similar to what Ferrari has done with Shell. Traditionally, I have read over the internet and on this forum that the preferred engine oil is Castrol TWS 10W60. I also understand some have used Castrol Edge Sport 0W40 and have seen good results. It's early for me as yet, but I spoke to our Chief Petroleum Engineer earlier this afternoon and his assessment is pure and simple.....show him an engine (apart from those that are consistently exposed to high pressure and temperature i.e. those that are frequently tracked/raced) that can breach a 40 heat grade and he would re-assess his job!!!! Now that's a serious claim. Given that, I asked my mechanic to pour 0W40 into my S50 engine : ). His response was, "Singh, lu suka buang luit ahhhh!!! Itu 5W40 sudah cukup la!!!" Being so new to the M, I chose the safer bet and went with the 0w40. Unfortuntely the brand had to be Castrol as no other brands available in Msia make such a blend. It is worthwhile to note that the Petroleum Engineer also assured me that in Msia with our humidity and temparature, that a blend of 5W40 is more than sufficient to manage the stress of the most challenging engine conditions. Most important is regular oil change at the right intervals and allow highly stressed engines the right to a well lubed engine at right temperature before pushing it. I further checked this point with our Chief Drilling Engineer who is responsible for oil rigs with massive gears that need to drill 3 km into the earth. These gears are changed every 500 metres or so as they give way!!! Talk about stressed engines....he completely agrees. He drives a E60 M5 and he uses a Fully Synthetic 5W40 for his ride. No trouble for the past 3 years he claims.A call to my previous owner confirms that he has been using Shell Ultra Helix 10w40 on the car for the past 2 years of his ownership. I don’t see any signs of wear or sludge or engine deprivation as yet. I chose a safer proven bet and used the 0W40 instead, however the 5W40 indicates that it would have worked just as fine or lesser cost and more options, based on research on paper and people who have the technical expertise around lubes.Also check out the following sites for some educated reviewshttp://forums.bimmerforums.com/forum/showthread.php?t=10033722. Transmission fluidAnother debated subject on whether to use ATF or MTL. I called BMW Malaysia for an answer this afternoon and their response was if you use any transmission fluid apart from BMW approved ATF on auto or manual trannies, the warranty is void. I spoke to some Engineer named Mr Lim from AB Glenmarie ( a rather rude guy!!!). I was a little suspicious and started to google this, and hey presto found some sites that say the same thing. Reviews on whether to use ATF or MTL with 75W80 grade (and some say 75W90) was mixed. My research remains inconclusive on this point as yetHowever, I drained my tranny fluid today and after reading various posts and checking with those in the know, I poured BMW approved ATF Dextron III into my tranny. Drove for 60 km’s and feels fine, no difference spotted as yet.Here are some overseas forum posting on tranny fluidshttp://www.uucmotorwerks.com/html_techtip/techtips/e36_fluids.htmhttp://m3forum.net/m3forum/showthread.php?t=294735http://forums.eurocca.net/showthread.php/31742-E36-M3-6-Speed-Gearbox-Oil-What-to-UseSome say Redline junk…some swear by it. I am indeed confused. I think the best thing to do is use Dextron III and flush every 5000km or use a 75W90 performance fluid and flush every 10000km. I dunno the answer to this one yet……any pointers???3. Diff oilSimilar argument to tranny oil as above and recommendation is 75W90. Some say use 75W140. There are mixed reviews on this……..Do I have an educated answer as yet…..on engine oil a big YES. Thanks to a forumer here and my colleagues at work. On tranny fluid and diff fluid, not really and hoping for those with experience to shareThanks!
Good info. End of day, seems like its a trial & error case.
Changing tranny fluid every 5000km to 10000km intervals seems kinda short IMHO. I do mine around 30000km with Redline MTL 75W90 on my 6MT S54. Same fluid for my rear diff.
For LSD, stick with bmw's original LSD oil with proper friction modifier in it. A little pricy but even one racing driver that owns a M5 and a workshop, having tried all types of oil, is back to Bmw's oem oil.
Thanks NKOTB and Bundy! I guess there is no right answer around this and our cars will except a "range" of fluids if I may say so. Ultimatey, it is about performance vs longevity and somehow I suspect the both are an innuendo. For me, I prefer longevity with that need for performance when I call for it.
Simply by the range of comments on fluids on various forums, is a storng indicator that ultimately it boils down to personal preference, within a tolerable range of spec.
Guys,
Pls share with me who you go to with your M rides for mechanical issues. Not many mechnanics entirely familiar with the car......
Thanks a million!
Been sticking with Castrol 10W60 for the last 1 and half year n happy with it. Also using the bmw oem fluid for the gb and diff. Only 2litres for gb so it doesnt hurt so much :wink:
So when is the 6speeder going into the car hehehe... It will be even better.
hey buddy.i have used castrol tws 10w 60 when i got the ride and now i am using revenol 10w 60 cuz its kindda great for my kindda driving and i noticed that the oil temp never shoots more than 100 with all the wacking all day long everyday.besides with the tws it does go above that.pertaining to ur driving lifestyle you should make ur decision on what u want to use.bmw's recommends tws not a must.....i go to ab glenmarie(for recovering previous history) and tan of autobahn workshop.great chap.
Enjoy urself mate M's are meant for satisfaction not for show
Saw TWS going for RM70 per litre at MSpeed today. Not sure if that is cheap or normal price.
Thanks bro!!! 6 speed....hehehehehe....the list as follows: -
1. remap/chip - Jan 2011
2. change to h&r springs - Feb 2011
3. h&r arb front and rear - March 2011
4. 6 speed gearbox - June/July 2011
That's the plan...but who knows kena lottery all settle one go!!!
Thanks bro! I do agree that the ///M is to be enjoyed and driven like she was Shakira on heat!!!!
Its been a week with the ATF fluid in my gearbox. It shifts miraculously better and easier. I seldom notice performance differences, but in this, it is a hands down winner by a mile from the Redline that was in the box previously
