anaksarawak
Official Member
- Jan 20, 2007
- 4,154
Anyone have tried the following DIY [video=youtube;7JbPGVxJNik]http://www.youtube.com/watch?v=7JbPGVxJNik[/video]
Iceduke;760964 said:it can be done as it is quite straightforward but as I didnt have the jacks..paid my mech to do it. labour is afterall only RM80 la...
anaksarawak;760923 said:astroboy can you share the supply shop contact? Is it the same as iceduke's contact and price? We need 6 liters for each change?
Iceduke;753505 said:managed to copy paste to text, this document also covers newer F10/F30. If any of u still want the orig doc, buzz me. Cheers
anaksarawak;761008 said:As per your documentation refer DEXRON III for E46 GM A5S360R / A5S390R Therefore DEXRON VI from Petron Canada is the compatible replacement? I may have to cancel my order RM200 for 6 litrs
astroboy;761009 said:http://en.wikipedia.org/wiki/DEXRON
Quote:
"All Dexron-III licenses expired permanently at the end of 2006"
Iceduke;770173 said:sarawak-son, as I recall D-III is dexron 3 but Toyota adds slight variation of substance in it for their own formulation. That is why it is not called Dexron but D3. To be safe, get ori Dexron III or use Dexron VI like I am using for my GM5.
AB, btw I tot all new toyota incl avanza uses T-IV? how come still D-III? hmm...boleh kah?
anaksarawak;770185 said:Car's gearbox is now filled 7.5 liters of Petro Canada Dexron VI for 3 weeks now. Its still as smooth as before not change in FC too but initially there sign of shift brake (means the gear stick for a second before it change) however all all adaptation are cleared with INPA its smoother now. No fault code but plan to flush for another session next month to properly clear the old DIII
Thanks
Strider74;786857 said:Guys,
where to check (on the car) what type of gearbox is installed to your car?
thanks
chaboy;837956 said:today will change my zf5 to dextron iv... with filter
on n42 engine....
