Castrol TWS vs Castrol RS
fuwah they let you back in after your constant pestering? as i said, analogue needle. as you said, LCD thus digital what for rotate unless it helps your dyslexia.
for people with this kind of meter:
http://www.stackltd.com/img/8130wh.gif
kindly install them level.
http://www.stackltd.com/img/400_402.jpg
you may install it rotated such that say 6 is at 12 o'clock position if your engine's peak power is at 6000rpm and you were advised to keep your revs in that region so you drive and ensure the needle is always roughly pointing straight up.
and next to this you may install this:
http://www.pivotjp.com/product/sg/img/sg-bp.jpg
with 1.8bar at 12o'clock if you were advised that optimal operating boost is 1.8 bar such that anytime you see your needle seeming to hover around 9 o'clock, you know something is amiss.
