E46 parts & maintenance
xcrave;615446 said:
This one very simple... ive done it recently... no need the OBD II com... all you need to do is follow this 3 simple step.
After all service
#1 Press the left Knob on dashboard for 5 second (Wait for the milage numbers to turn TEST / RESET)
#2 Turn the Key To Position 1
#3 Release the Knob and Press again 5 Second
If all goes well the service meter will reset ...
Ive done it on my E46 320/323i :) Good luck
sorry off-topic....
how to reset the mileage to 0.0 after refuel...?
sorry, i'm noob
M3addict;615806 said:
sorry off-topic....
sorry, i'm noob
just press the left knob (at the dashboard meter console) once after starting engine :)
Thanks xcrave for the very useful information. But what is the mileage after one resets it? 25k?
xcrave;619489 said:
around 26K i think... hmmm depends on the Car Series :) cheers
sorry to ask....
coz there got 2 reading right.....
1 with 100k++ km, the other was 3 digit only where the max is 999km and will turn to 0 afterwards.
i want to reset the 3 digit reading to 0 (zero) everytime i refill fuel on my e46.....
have try to press the left knob (at the dashboard meter console) once after starting engine.
but nothing happen?
thx for ur advise
After all service
Bro Xcrave
Hi there I just want to clarify the steps to reset milage mention above is the milage reading when we turn on the key before starting the engine, in which the reading for the milage inspection? If its the one then I can service my ride thru a normal mechanic
Today got my E46 sideskirting (both side) sprayed. Badly bruised and scratched due to road condition and parking. Did it at Mantin Ng Sembilan (so happened I am working at this side of the world). Job well done by a veteran Uncle name Ah lek at Batu 8. Cost for both side RM150. Any bros from Nilai or Seremban area want fast touch up, can contact me via PM for the uncle's no. BTW both side done in 1 1/2 hrs....cheers
4/6/07:
took delivery of my E46 318i M43
16/6/07:
Cobra alarm system (metalink) - RM1650
30/6/07: (25,000 km service)
5 ltr engine oil - 112.50
1 pcs oil filter - 35.00
4 pcs plug - 140.00
1 pcs air cond micro filter - 98.00
1 pcs fuel filter - 88.00
1 pcs auto filter (atf) - 125.00
1 pcs auto gasket (atf) - 55.00
1 set front disc pad - 175.00
1 pcs front disc pad sensor - 45.00
7 ltr atf oil (ori) - 455.00
radiator coolant - 30.00
labour (for major service) - 160.00
wash - 20.00
TOTAL= 1,538.50
14/7/07:
power window rear left - 370.00
18/8/07:
alignment - 37.50
4 valves - 20.00
4 michelin xm1 205/60r15 - 1060.00
TOTAL = 1,117.50
10/9/07
vkool elite & v40 - 2600.00
1 set crystal no plate & casing - 170.00
TOTAL = 2,770.00
19/10/07
repair 7" crackline - 200.00
27/10/07 (37,500 km service)
4ltr engine oil fully synthetic & oil filter - 190.00
top hose - 140.00
expansion tank - 300.00
TOTAL = 630.00 (including labour)
12/12/07
3 lightbulbs (rear) - 15.00
31/12/07
front brakepad (ate) - 160.00
front lower arm bush - 350.00
alignment - 50.00
adjust rear camber - 50.00
off wheel balancing - 32.00
on wheel balancing - 16.00
TOTAL = 665.40 (plus tax & labour)
18/2/08
1 h7 headbulb - 28.00
22/3/08 (50,000 km service)
oil filter + 4ltr engine oil + labour - 190.00
22/3/08
bought @ inner power
rear ate disc pad - 115.00
rear brembo brake disc set - 310.00
TOTAL = 425.00
labour charge to change rear brake pad & brake disc - 70.00 (on 1/4/08)
31/3/08
alignment & balancing - 155.40 (plus tax & labour)
5/4/08
new alpine ida-x001 ice+speakers - 3,000.00
17/5/08
re-spray right hand side of the car - 600.00
2/7/08
19/7/08 (62,500 km service)
4 ltr mobil 1 engine oil - 198.00
1 set auto filter & gasket - 168.00
6 ltr ori auto oil (atf) - 270.00
labour - 120.00
TOTAL = 791.00
27/8/08
1 pcs radiator assy - 750.00 (plus labour)
3 ltr coolant - 60.00
TOTAL = 810.00
30/12/08 (75,000 km service)
oil filter - 28.00
labour - 35.00
TOTAL = 63.00
31/12/08
alignment & balancing - 181.65 (plus tax & labour)
2/1/09 (yet to be installed)
brembo front brake disc set - 350.00
front disc pad set - 130.00
TOTAL = 480.00
labour to install the disc and pad - 160.00 (on 21/2/09)
17/1/09
re-setting alarm system - 350.00
29/4/09
connector pipe for coolant - 58.00
coolant hose (rear) - 175.00
labour - 85.00
TOTAL = 318.00
10/6/09
(labour) oil filter housing gasket & O ring - 90.00
gasket - 28.00
2 pcs O ring - 20.00
1 pcs belt - 70.00
TOTAL = 208.00
06/07/09
re-spray 16' rims 4pcs - 200.00
11/07/09 (87,500km service)
oil filter - 45.00
labour - 45.00
TOTAL = 90.00
01/08/09
labour - 60.00
fr lh window lifter - 430.00
TOTAL = 490.00
06/08/09
fr h7 lamp bulb - 38.00
15/08/09
205/55/zr16 michelin pp2 4 pcs - 1,688.00
steel valves 4 pcs - 48.00
balancing, alignment, camber - 143.00
TOTAL = 1,886.15 (plus tax)
18/01/10 (100,000km service)
1 pcs oil filter - 45.00
4 pcs bosch spark plug - 140.00
2 pairs brake pad (front & rear) - 370.00
2 pcs brake sensors - 76.00
oil service - 45.00 (oil self-supplied)
labour - 260.00
TOTAL = 936.00
05/02/10
top up air-cond gas - 50.00
02/03/10
1 pc front emblem - 52.00
2 pcs grommet for emblem - 6.00
TOTAL = 58.00
13/04/10
front R/H window lifter - 430.00
labour - 80.00
TOTAL = 510.00
20/04/10
ignition coil - 520.00
diagnose engine misfire & labour - 60.00
TOTAL = 580.00
03/05/10
air vent valve - 185.00
labour - 45.00
TOTAL = 230.00
18/05/10
air filter - 38.00
microfilter - 65.00
(self installed)
TOTAL = 103.00
12/06/10
alignment + balancing = 183.75
17/06/10
front right hand bumper bracket = 130.00
03/07/10 (112,500km service)
engine oil - 209.00
oil filter - 45.00
rear left wheel bearing - 135.00
brake fluid - 38.00
labour - 305.00
TOTAL = 732.00
12/07/10
alignment - 131.25
14/08/10
ori wiper set - 110.00 - self DIY
front windscreen lower panel cover - 228.00 (installed on 13/11/10)
TOTAL = 338.00
13/11/10 (125,000km service)
engine oil - 209.00
oil filter - 45.00
deflect pulley 2pcs - 140.00
fan belt - 65.00
labour (service + install windscreen cover) - 90.00
TOTAL = 549.00
19/11/10:
4 pcs 225/45r17 Eagle F1 Asym - 2060.00
(installed on 3/1/11)
3/1/11:
steel valve - 10.00
alignment - 125.00
fix new tires - 48.00
balancing - 20.00
TOTAL = 212.65 (plus tax)
29/1/11:
oil sump gasket - 55.00
drain & replace oil - 25.00
labour - 180.00
TOTAL = 260.00
26/3/11:
1 set front brake pad - 280.00
2 front brake disc - 520.00
brake fluid - 35.00
2pcs engine mounting - 290.00
FLH lower arm - 150.00
labour - 100.00
TOTAL = 1,375
QD250;622303 said:
4/6/07:
26/3/11:
brake fluid - 35.00
labour - 100.00
TOTAL = 1,375
Bro very reasonable price you get they, i believe u bought the parts by your self and get change from the workshop right ?
Why so many time your brake and bulb replacement?
QD250;622303 said:
4/6/07:
16/6/07:
4 pcs plug - 140.00
wash - 20.00
TOTAL= 1,538.50
14/7/07:
18/8/07:
alignment - 37.50
4 valves - 20.00
TOTAL = 1,117.50
10/9/07
TOTAL = 2,770.00
19/10/07
top hose - 140.00
12/12/07
31/12/07
alignment - 50.00
18/2/08
22/3/08
TOTAL = 425.00
31/3/08
5/4/08
17/5/08
2/7/08
labour - 120.00
TOTAL = 791.00
27/8/08
TOTAL = 810.00
oil filter - 28.00
labour - 35.00
TOTAL = 63.00
31/12/08
TOTAL = 480.00
17/1/09
29/4/09
labour - 85.00
TOTAL = 318.00
10/6/09
gasket - 28.00
1 pcs belt - 70.00
TOTAL = 208.00
06/07/09
oil filter - 45.00
labour - 45.00
TOTAL = 90.00
01/08/09
labour - 60.00
TOTAL = 490.00
06/08/09
15/08/09
labour - 260.00
TOTAL = 936.00
05/02/10
02/03/10
TOTAL = 58.00
13/04/10
labour - 80.00
TOTAL = 510.00
20/04/10
TOTAL = 580.00
03/05/10
labour - 45.00
TOTAL = 230.00
18/05/10
air filter - 38.00
microfilter - 65.00
(self installed)
TOTAL = 103.00
12/06/10
17/06/10
engine oil - 209.00
oil filter - 45.00
brake fluid - 38.00
labour - 305.00
TOTAL = 732.00
12/07/10
alignment - 131.25
14/08/10
TOTAL = 338.00
13/11/10
engine oil - 209.00
oil filter - 45.00
fan belt - 65.00
TOTAL = 549.00
19/11/10:
3/1/11:
steel valve - 10.00
alignment - 125.00
balancing - 20.00
29/1/11:
labour - 180.00
TOTAL = 260.00
26/3/11:
brake fluid - 35.00
labour - 100.00
TOTAL = 1,375
Alex5522;622373 said:
QD250;622303 said:
4/6/07:
26/3/11:
brake fluid - 35.00
labour - 100.00
TOTAL = 1,375
Nope, didn't buy the parts myself...
read again, I changed my brake disc every 2 years..... not necessary though....
brake pad maybe once a year....
reason: my style of driving requires it....
the bulb are not the same bulb.... one by one they are dying in this 10 yr old car...
