E46 parts & maintenance
zul_cessna;637755 said:
my car also due for servicing and i'm also using castrol edge 5w/40, looks like i have to go to the same workshop as yours B33Mer
I bought the oil at tyre zone branch in Damansara uptown and change the oil at my mech, elegance autoimage, at jalan 222 :4:
bmw7833;637757 said:
I just bought mine from them today, Tmn Megah branch.
How many bottles did you buy bro?
hi guys, im new here and thinking to change my engine mounting...the vibration is getting worse..anyone can help??please advice and recommend me a gud workshop with reasonable price...im staying in PJ...thanks
zul_cessna;639669 said:
Went to Bavarian Auto, subang jaya, they currently having promotion for BMW engine oil, RM 35 per litre.
Thanks for the info bro ... called them up and the viscocity is 5W-40 :top: Could be old stocks they need to clear but am not sure.
I did asked and they said till stock finished, could be the old stock. by the way by the time i know, already bought castrol edge 5/40 from tyre zone. paid rm 301 for 2 bottles
Lost powered brake after breakfast this morning. Change the master pump and another thing behind the engine, total to rm990. :motz:
Routine service end up changing a number of parts due to wobbling steering feel at straight line:
Parts
1. Engine oil filter 1@RM48.00
2. Ribbed belt 1@RM190.00
3. Thermostat housing 1@RM195.00
4. Steering rubber cover 1@RM95.00
5. Bosch spark plug 6@RM48.00
6. Hup cap 1@RM82.00
7. Ravenol 5W-30 (5L) 1@RM260.00
8. Ravenol 5W-30 (1L) 2@RM65.00
9. Engine Mounting 2@RM190.00
10. Control arm bush set 1@RM380.00
11. Lower Arm (L & R) 2@585.00
Labour for the above work RM200.00
Additional labour for changing Vanos Seal (& reset timing) RM200.00
Total damage RM3,618.00
Parts
Bro which workshop did you have the parts changed?
Salam Bro E33mEr,
I tried to PM you but your inbox full la. Please try to delete some old message and make space for new mail.
Thank you.
morrogan;643292 said:
Salam Bro E33mEr,
Thank you.
Bro would it be better just let all of us know & share here instead of pm.
Thanks.
Salam Bro E33mEr,
Thank you.
Thanks bro ... PM replied :4:
hi, im newbie in this website.
last week i just changed item below in jb.
enginer oil(liqui moly) 5 liter - RM260
oil filter - rm35
servo unit(booster) - rm1000
vacuum pump(ori) - rm1500
tangki - rm700
spare tangki - rm300
NGK plantium plug 4pcs - rm140.00
tensioner,belt & bearing - rm500.00
brake pad(front) ori - rm340
(rear) ori - rm300
brake sensor - rm30
change oil seal and oil sham - rm300
seat mat sensor - rm600.00
total labour charge -rm600
is this expensive or reasonable?thks
oil filter - rm35
tangki - rm700
(rear) ori - rm300
brake sensor - rm30
Holy Moly! kena potong sikit2 but... why change a lot of item ??? the car got major problem with the fuel tank??
Airbag warning on???
water leaking, oil leaking,brake got problem,airbag light is on.
because i buy second hand car ,so get mechanic to check the problem for me.
oil filter - rm35
tangki - rm700
(rear) ori - rm300
brake sensor - rm30
Which E46 model u own? which & where is this wokshop in JB?
