E46 Part and Service Cost II
wsonny;844131 said:
Auto filter GM = RM78
Auto gasket GM Ori = RM168
ATF oil GM = RM336 (7ltr)
Oil filter housing O ring = RM70 (2pc)
Radiator = RM800
Engine Oil = RM156
Oil Filter Ori = RM45
Gear Level Oil Seal = RM30
Coolant = RM38
Workmanship = RM200
Total = RM1921
The gurus here gave me a contact to buy the Behr radiator at 550.
Can share with me the contact as well?
Sent from my Nexus 4 using Tapatalk 4
Terry, can't wait for another source. Coz I just change the holes the when I do the water pleasure test then only know the leak. So hav to change immediately if not I can't drive outstation the next day
Hi i just want to highlight that sometimes when one supplier give you a good price it doesnt mean that he has the best price for everything. So you need to call up everyone. Gurus like Wingzee, Anak Sarawak and Iceduke are some of the gang i consult about approximate price so that i can negotiate with the suppliers (sorry i miss mentioning some of our other gurus who helped me).
I bought the radiator just last week from Bomin - please specify you want Behr (advice from gurus and also i tried a taiwanese radiator before and it lasted less than 1 year)
Other suppliers to call up are CSS auto, Munich auto or BA. Also check with those gurus.
Bomin has one more unit of Behr if i am not wrong - i had to wait 2 weeks for the Behr becoz they were all pushing another brand
I m looking for behr as well. Got a contact at lowyat forum selling it as well, will keep it updated here if I got better price.
Sent from my GT-N8000
terry8;844745 said:
Bomin has one more unit of Behr in stock
Behr is the oem? I also got quote for what is claimed to be "original banco" for rm580. Not sure what is the brand of existing one
terry8;844749 said:
My understanding is Behr is the OEM
Went to change my radiator @ bomin but no luck, Behr was out of stock, so I just buy whatever in stock, can't even remember the brand name. Bought it for RM550. Changed it yesterday, drive about 300km, found out water level drop a lot, refilled, monitoring the water level now. Hope no more leaking, just need to topup once bcoz it wasn't completely filled before.....
Finally, done the most important part of cooling system maintenance...
BERH Radiator RM480
Cover Plate RM280
BERH Expansion Tank RM250
Labor RM120
Workshop = Bomin
Toyota Long Life coolant x 2 = RM40
Called to BA HQ. They are not selling BERH Radiator. But they have so call BMW OEM Radiator without logo selling RM700++ ....hmmm......
BERH Radiator RM480
Cover Plate RM280
Labor RM120
Workshop = Bomin
How come u can get BEHR, when I ask when they re replenishing the stock, they said not gonna restock soon. I guess they re just pushing their existing stock. This is not good. I even paid more than RM440, RM550 to be exact, for a brand that even the guy in the counter can't pronounce.
Sigh..
*assuming your BERH is a typo of BEHR :p
Got OEM crankshaft, camshaft (intake) and camshaft (exhaust) from online for E46 325
for US $39.99 and postage for US $23.95.
USD39.99 for all three?
- - - Updated - - -
Yes, USD for39.99 all 3 sensors from ebay. quite reasobale considering that the crankshaft is RM180 and camshaft (intake) is RM330 from Bavarian Auto.
A visit to Bomin today :)
1. Boge abs automatic frt Rm280
2. Boge abs automatic rr Rm145
3. Lemforder frt abs mounting Rm70
4. Frt tube Rm12
5. Frt abs damper Rm20
6. Frt upper spring pad Rm25
7. Frt lower spring pad Rm25
8. Lemforder rr abs mounting RM30
9. Rr abs damper Rm20
10. Rr abs tube Rm10
11. Rr upper spring pad RM 28
12. Rr lower spring pad RM30
13. Centre mount Rm90
14. Universal joint Rm130
15. Gearbox mounting Rm35
- - - Updated - - -
4. Frt tube Rm12
Sorry for coming in here late. I have just added a younger brother (E46 318i 1.9) for my E39 523i.
I am surprised that within 1.5 years you have changed so many parts of the E46; some major items were changed more than twice within that period - absorbers and lower control arms for example.
wingzee;835669 said:
These are list of part prices which I have compiled throughout the 1.5yrs of my ownership of the E46. Some parts may only be applicable for M54B25 and might subject to change by stockist. Hope this will be helpful to all E46 owners & more will contribute to the E46 community.
Engine (consumables):
--BMW oil filter RM35
--BMW Super 5W-40 - RM25/L (7L required)
--Spark plugs (NGK Laser Platinum) RM17 per pc, BKR6EQUP - RM38
--Bosch FGR7DQP RM18/Denso Iridium K20TXR
Engine:
--Valve seals RM86 (Victor-Reinz)
Full job /w parts RM850 (Albert), RM600 (Taiping)
--Fuel pump RM375
--Oil drain plug RM10
--Oil sump gasket RM55 (labour RM180)-Victor Reinz
--Fuel filter-Kaiser (13327512019) RM100
--Ignition coil (12131712219) RM80 (Bosch)
--MAF (13627566984) RM546
--ICV (13411744713) RM530
--CVV/Oil separator RM225
--Breather vent hose RM130
--Crankshaft position sensor (VDO)(12141709616*RM185)
--Camshaft sensor (intake) (Vaico/Hella)(12147539165)*RM170; RM377 (Ori BMW)
--Camshaft sensor (exhaust) (Vemo)
(12147518628)
--Camshaft O-ring (12141748398, x2, $1.20)
--DISA valve (11617502269/11617544805) RM710
--O2 sensors (Bosch)
-Pre-cat RM343 (11787503441) & RM387
(11781437586)--for fuel management
-Post-cat x 2 (11781433940)--for monitoring purpose only
--Engine mounting (Corteco) RM97 ea
--GB mounting (Lemforder) RM27 ea
--Valve cover gasket (11129070990*$38.65) RM100
--Valve cover seal grommet/seal (15pcs)
(11121437395 $ 1.05)
--Labour 60/70
--Engine full overhaul RM4k
--Alternator (12317501687)
*RM750 (90A)
*RM1400 (120A:*12317501599)
--Voltage regulator $53 (Pulsating interior lights)
--Electric fan RM880
Cooling system:
--Radiator cap RM28
--Temp sensor (Coolant) (13621433077)
--Thermostat 1 (11531437040) (Housing/Engine) RM154
--Thermostat 2 (17111437362) (Radiator/expansion tank) RM198
--Water pump (11517527910) RM310/RM115 (Saleri), RM180 (Meyle)--replace every 100-120k
--Heater/water valve (64118369805) RM450
--Bleeder screw RM11
--BMW coolant RM30
--Toyota coolant RM17
Gearbox:
--ESSO LT 71141/ZF Lifeguard5/BMW PN#*83 22 9407 807/907 RM39 per bottle (9L /w torque converter, 6.2L w/o)
--ATF filter (Filtran*24341423376) RM33
--ATF pan/sump gasket (24101423380) RM30
--Torx bolt (24101423273) $1.68ea
--Flywheel oil seal (11142249533) RM33 (normal), RM65 (Teflon /w spring)--Victor Reinz
-E46 heat exchanger (17227505826) RM322
Rear axle:
--Rear trailing arm bushing (33326770786*$26.77ea)
--Rear subframe bushes (x7: RM900)
--Rear trailing arm bushes (x10: RM1000)
Rear axle differential:
--Shaft seal (centre)*31507609535*RM36ea (1pc)
--Shaft seal /w lock ring (sides)*33107505604*RM45ea (2pcs)
--Axle oil (75w90) RM22 per L
*Last changed 191,000km (Last about 80-100k km)
--Absorbers:
-Bilstein B4 RM860 (Bomin), RM970 (First Division - 6mths warranty), RM920 (Munich Auto - 1mnth warranty)
-Bilstein B6 RM2.1k
-Bilstein B8 RM2.6k
-Koni Yellow RM2.6k (installation inclusive)
-TITAN RM2.6k (installation inclusive)
-Bump stop RM25 ea
*Front mount RM85 ea
*Rear mount RM35 ea
*Installation RM200
Control Arms:
--Meyle RM385 (First Division)
--Lemforder RM420 (BA)
Steering rack:
--Original ZF RM3.5k (Stuttgart)
--Original ZF RM2.8k (First Division)
--Recond ZF RM1.6k (3 mths warranty - trade in old)
--Recond ZF RM700 (1 mth warranty - trade in old)
Steering column:
-Steering shaft RM250/600 (Albert)
Steering joint:
--Lower joint Assy
(32306761570*$159.58) #3
RM525
--Swivel joint with *universal joint
(32306761571*$70.85) #4/5
RM310
*Labor cost RM60
Brakes:
--Brake rotors (FR) Ori BMW RM262 per pc, Lemforder/Febi RM120 per pc
--Wheel bearing RM135
--Front RH window lifter RM430
--Brake pads
Front-Textar/ATE RM100
Rear-ATE RM80
--Brake sensor RM24 (front/rear)
--Brake fluids (every 15k km) RM50 (BMW), Bosch Dot4 RM30
--Brake repair kit RM38 per side
--Headlight levelling sensor (37146784696*$85.28)
--Sensor front angle joint (37146766778/31121093958 $13.28)
--M3 solid rubber CAB RM170 (Munich Auto)
--ARB bush (front) RM68 per pair
--Tie rod-Febi (32106777503) RM170
--Lower arm-Meyle RM410/pc, Lemforder RM480/pc
Wiper refill:
--Dura Edge RM80 (Dura Tech Supplies Sdn Bhd)
Power windows:
--Window lifter switch, passenger
61316902179*RM185
Door trim:
--Door weatherstrip (rear right)
51348194697*($84.48)
Lighting (exterior):
--Inner reverse/fog lamp RM175
--Side indicators (Uno BMW) RM50
Batteries:
--Panasonic/Century/Yokohama
---DIN66 RM330/RM300/RM199
--Century Marathoner RM330
*Bosch S3 RM275
---DIN88 RM390
---DIN100 RM430
Aircond:
--Cooling coil (OEM) RM1500 (1yr warranty) /w workmanship; Ori RM1800 (3mnths warranty)
*Naidu
-Receiver dryer/pressure switch
-Expansion valve
-Vacuum top up compressor oil/gas
-1 set O ring
-Full aircond service
-Labor to remove dashboard
--GB rebuild:
-M-Scope *(RM6.1k)
->Gearbox overhaul kit, oil pump RM1.5k, solenoid switches (only few changed-RM180 per pc), ATF & auto filter, oil cooler (get air cooled one), service valve body, service torque converter, labour
->Gear selection switch (optional - RM900) -- BA selling RM530
->Rebuild torque converter (optional - RM700)
--M-Scope: RM6.5k /w recond torque converter. Others all new ZF parts. 1 year warranty (2yr warranty - 8k)
--TC rebuild RM1350, labour RM270, 2pcs manifold gasket flut RM78, ATF oil 2.5l RM120
Good day all. I'm a new member from kluang, johor. Need some info for price of changing these items: 1) flywheel oil seal 2) crank shaft oil seal 3) power steering hose. Already asked outside mechanic about the price. He asking for rm1+++. Is it the appropiate price? Thanks all
Hye guys...! Need some guide on repairing wiper water sprinkler. Mine was not functioning. Dont whats the problems. Usually, what is the cause of this & how much to repair? Thanks guys.
