E46 parts & maintenance
Latest damage due to overheat:
Water pump = RM295
Adapter = RM120
Labor+misc = RM150
StopMe_;571593 said:
E46 2.0 4-potter.
normal driving habit full tank can give 550km to 600km mix highway+city. :driver:
Crazy driving habit, full tank can give up to 480km only.:39:
Bro ur car seem to be good on FC btw what is your tyres size ?
Date: 15/10/2010
Benzone Auto Care.
Hose Clip - RM 8.00
Temp Sensor - RM 115
E46 Radiator - RM 850
E46 Water Pump - RM 220
Thermostat - RM 265
Hose - RM 115
Oil Level Sensor - RM 285
Labour - RM 270
hi guys, just bought my 318ci, im having problem with my coolant...heheh i was so surprised when found out there was no reserve tank for beemer...the problem that i facing now is that my coolant is always dry, but the engine is not overheated at all and my oil engine never reduce..for rm120 my full tank can go 700km city+highway with 18" rim...
need your guys advice what should i do and check for the coolant system..and can you recommend me the mechanic shop near PJ or shah alam...
Latest service at Autobahn Specialist sunway.
1. Revenol 10W-60 2 bottle - RM460 (the balance i reserve for next srvice)
2. Oil Filter - RM30
3. Revenol 5HP gearbox oil 6 Litre - RM360
4. Oil Pan - RM80
5. Gasket - RM80
6. Revenol Rear Axle Oil 2 Litre - RM76
7. Labour - RM50
Total = RM1136.00
:rock:
4. Oil Pan - RM80
5. Gasket - RM80
7. Labour - RM50
Total = RM1136.00
:rock:
Murahnya labour cost
StopMe_;571438 said:
Latest damage:
V-belt = RM68
Bearing = RM118
Engine oil (Petronas Mach5 20w50) = RM99
Labour + Car wash = RM100
Mr car has started 'makan' engine oil... have to use higher SAE engine oil. before this I use 5w40 or 10w40 shell.
Wow, mineral oil for E46? Do you feel any difference in performance when using this Mach 5 20w-50?
Btw, my missus' E46 2.0 had the issue of makan minyak too until we switched to Total 10w-50 (fully synth).
4/6/07:
took delivery of my E46 318i M43
16/6/07:
Cobra alarm system (metalink) - RM1650
30/6/07: (25,000 km service)
5 ltr engine oil - 112.50
1 pcs oil filter - 35.00
4 pcs plug - 140.00
1 pcs air cond micro filter - 98.00
1 pcs fuel filter - 88.00
1 pcs auto filter (atf) - 125.00
1 pcs auto gasket (atf) - 55.00
1 set front disc pad - 175.00
1 pcs front disc pad sensor - 45.00
7 ltr atf oil (ori) - 455.00
radiator coolant - 30.00
labour (for major service) - 160.00
wash - 20.00
TOTAL= 1,538.50
14/7/07:
power window rear left - 370.00
18/8/07:
alignment - 37.50
4 valves - 20.00
4 michelin xm1 205/60r15 - 1060.00
TOTAL = 1,117.50
10/9/07
vkool elite & v40 - 2600.00
1 set crystal no plate & casing - 170.00
TOTAL = 2,770.00
19/10/07
repair 7" crackline - 200.00
27/10/07 (37,500 km service)
4ltr engine oil fully synthetic & oil filter - 190.00
top hose - 140.00
expansion tank - 300.00
TOTAL = 630.00 (including labour)
12/12/07
3 lightbulbs (rear) - 15.00
31/12/07
front brakepad (ate) - 160.00
front lower arm bush - 350.00
alignment - 50.00
adjust rear camber - 50.00
off wheel balancing - 32.00
on wheel balancing - 16.00
TOTAL = 665.40 (plus tax & labour)
18/2/08
1 h7 headbulb - 28.00
22/3/08 (50,000 km service)
oil filter + 4ltr engine oil + labour - 190.00
22/3/08
bought @ inner power
rear ate disc pad - 115.00
rear brembo brake disc set - 310.00
TOTAL = 425.00
labour charge to change rear brake pad & brake disc - 70.00 (on 1/4/08)
31/3/08
alignment & balancing - 155.40 (plus tax & labour)
5/4/08
new alpine ida-x001 ice+speakers - 3,000.00
17/5/08
re-spray right hand side of the car - 600.00
2/7/08
19/7/08 (62,500 km service)
4 ltr mobil 1 engine oil - 198.00
1 set auto filter & gasket - 168.00
6 ltr ori auto oil (atf) - 270.00
labour - 120.00
TOTAL = 791.00
27/8/08
1 pcs radiator assy - 750.00 (plus labour)
3 ltr coolant - 60.00
TOTAL = 810.00
30/12/08 (75,000 km service)
oil filter - 28.00
labour - 35.00
TOTAL = 63.00
31/12/08
alignment & balancing - 181.65 (plus tax & labour)
2/1/09 (yet to be installed)
brembo front brake disc set - 350.00
front disc pad set - 130.00
TOTAL = 480.00
labour to install the disc and pad - 160.00 (on 21/2/09)
17/1/09
re-setting alarm system - 350.00
29/4/09
connector pipe for coolant - 58.00
coolant hose (rear) - 175.00
labour - 85.00
TOTAL = 318.00
10/6/09
(labour) oil filter housing gasket & O ring - 90.00
gasket - 28.00
2 pcs O ring - 20.00
1 pcs belt - 70.00
TOTAL = 208.00
06/07/09
re-spray 16' rims 4pcs - 200.00
11/07/09 (87,500km service)
oil filter - 45.00
labour - 45.00
TOTAL = 90.00
01/08/09
labour - 60.00
fr lh window lifter - 430.00
TOTAL = 490.00
06/08/09
fr h7 lamp bulb - 38.00
15/08/09
205/55/zr16 michelin pp2 4 pcs - 1,688.00
steel valves 4 pcs - 48.00
balancing, alignment, camber - 143.00
TOTAL = 1,886.15 (plus tax)
18/01/10 (100,000km service)
1 pcs oil filter - 45.00
4 pcs bosch spark plug - 140.00
2 pairs brake pad (front & rear) - 370.00
2 pcs brake sensors - 76.00
oil service - 45.00 (oil self-supplied)
labour - 260.00
TOTAL = 936.00
05/02/10
top up air-cond gas - 50.00
02/03/10
1 pc front emblem - 52.00
2 pcs grommet for emblem - 6.00
TOTAL = 58.00
13/04/10
front R/H window lifter - 430.00
labour - 80.00
TOTAL = 510.00
20/04/10
ignition coil - 520.00
diagnose engine misfire & labour - 60.00
TOTAL = 580.00
03/05/10
air vent valve - 185.00
labour - 45.00
TOTAL = 230.00
18/05/10
air filter - 38.00
microfilter - 65.00
(self installed)
TOTAL = 103.00
12/06/10
alignment + balancing = 183.75
17/06/10
front right hand bumper bracket = 130.00
03/07/10 (112,500km service)
engine oil - 209.00
oil filter - 45.00
rear left wheel bearing - 135.00
brake fluid - 38.00
labour - 305.00
TOTAL = 732.00
12/07/10
alignment - 131.25
14/08/10
ori wiper set - 110.00 - self DIY
front windscreen lower panel cover - 228.00 (installed on 13/11/10)
TOTAL = 338.00
13/11/10
engine oil - 209.00
oil filter - 45.00
deflect pulley 2pcs - 140.00
fan belt - 65.00
labour (service + install windscreen cover) - 90.00
TOTAL = 549.00
need help from u all.I buy my e46 320I in 5/2006.That car register is 2001,the saleman also told that my car 2001..after 4 years,just knew my car is 1999.i checked from car serial no and during dignosis,it told that my car is 1999..i suggestions???
I am afraid there is nothing you could do but to knock your head against any wall. You have been conned!! It is for this very reason why many potential and current beemers are in BMWCM for there are plenty of useful information.
ermm...i tough my engine m54 also..after checked it m52..want to cry nowww...like to buy new lancer gt..i hope the saleman will die soon...can i make report on this or slow talk again with the saleman..the shop still have in klang..
As Herbert mantioned, you were conned and it's always advisable to know about the car before buying. Google and BMWCM helps allot. There are differences between M52 and M54 which you can notice. Another thing is that you should bring someone who knows about these cars along to atleast check.
Dude, you were conned 4 yrs ago...
Bro merz_e46,
Take this purchase of yours as a lesson learnt and be wiser next time. No point making a report or talk to the salesman for they will deny everything. Whatever happened has happened and don't drool over it. Get your car to a mechanical satisfactory condition and enjoy the ultimate driving machine.
herbert;583217 said:
Bro merz_e46,
thanks bro..it ok now..im happy with my car performance and new paint..just the radio and the car year 1999 not 2001..i like my car..i upgrade my car step by step but no too much...
hi all!!!just want to share my experience with my e46. currently, I sent my car this month to Ultra Tune (as reckon by sifus in this forum) to replace brake piping for left rear brake due to some leakage and the brake is not balance and tend to move to the left. the brake caliper also need to be replaced due to corrosion. I also asked them to paint my rim, brake caliper and disc brake. so here are the cost;
brake piping (machining in factory) : rm150
disc brakes (rear) (2nd with 80%) : rm380
caliper rear (both) (2nd) :rm370
paint rim all : rm720
paint caliper all : rm780
paint brake disc all : rm80
brake oil : rm80
alignment/balancing : rm70
labour : rm720 (include services the brake, check the steering rack, anti-rust paint,inspection,wash,vacuum and polish,refill fuel tank)
government tax 5%
overall the customer services is very good 5star!!I totally reckon this workshop.they are totally helpful.they done so much to my car.very neat workmanship!! now I can be on the road with smile everyday!!
Small maintenance and the usual oil change:
Front window regulator (ori) x 1: RM320
Labour charge: RM80
Bardhal Fully Synthetic 5W-40: RM85 x2 = RM170
Oil Filter and Labour charge : RM40
Rear bulb holder both sides (OEM) = RM112 x 2 = RM224
New sockets, wire clamps and labour charge = RM50
Next on the list is GB and differential oil change, spark plugs and fuel filter ... :D
Change oil after 7,000 km
castrol edge 5w-40 : RM 160 x 2= RM320
oil filter original = RM 40
labour = RM 30
Total = RM 390.00
change differential oil = RM 36
change vanos hose = RM 85
labour = RM 60
Total = RM 181
Big Total spend = RM 571.00
