E46 parts & maintenance
4/6/07:
took delivery of my E46 318i M43
16/6/07:
Cobra alarm system (metalink) - RM1650
30/6/07: (25,000 km service)
5 ltr engine oil - 112.50
1 pcs oil filter - 35.00
4 pcs plug - 140.00
1 pcs air cond micro filter - 98.00
1 pcs fuel filter - 88.00
1 pcs auto filter (atf) - 125.00
1 pcs auto gasket (atf) - 55.00
1 set front disc pad - 175.00
1 pcs front disc pad sensor - 45.00
7 ltr atf oil (ori) - 455.00
radiator coolant - 30.00
labour (for major service) - 160.00
wash - 20.00
TOTAL= 1,538.50
14/7/07:
power window rear left - 370.00
18/8/07:
alignment - 37.50
4 valves - 20.00
4 michelin xm1 205/60r15 - 1060.00
TOTAL = 1,117.50
10/9/07
vkool elite & v40 - 2600.00
1 set crystal no plate & casing - 170.00
TOTAL = 2,770.00
19/10/07
repair 7" crackline - 200.00
27/10/07 (37,500 km service)
4ltr engine oil fully synthetic & oil filter - 190.00
top hose - 140.00
expansion tank - 300.00
TOTAL = 630.00 (including labour)
12/12/07
3 lightbulbs (rear) - 15.00
31/12/07
front brakepad (ate) - 160.00
front lower arm bush - 350.00
alignment - 50.00
adjust rear camber - 50.00
off wheel balancing - 32.00
on wheel balancing - 16.00
TOTAL = 665.40 (plus tax & labour)
18/2/08
1 h7 headbulb - 28.00
22/3/08 (50,000 km service)
oil filter + 4ltr engine oil + labour - 190.00
22/3/08
bought @ inner power
rear ate disc pad - 115.00
rear brembo brake disc set - 310.00
TOTAL = 425.00
labour charge to change rear brake pad & brake disc - 70.00 (on 1/4/08)
31/3/08
alignment & balancing - 155.40 (plus tax & labour)
5/4/08
new alpine ida-x001 ice+speakers - 3,000.00
17/5/08
re-spray right hand side of the car - 600.00
2/7/08
19/7/08 (62,500 km service)
4 ltr mobil 1 engine oil - 198.00
1 set auto filter & gasket - 168.00
6 ltr ori auto oil (atf) - 270.00
labour - 120.00
TOTAL = 791.00
27/8/08
1 pcs radiator assy - 750.00 (plus labour)
3 ltr coolant - 60.00
TOTAL = 810.00
30/12/08 (75,000 km service)
oil filter - 28.00
labour - 35.00
TOTAL = 63.00
31/12/08
alignment & balancing - 181.65 (plus tax & labour)
2/1/09 (yet to be installed)
brembo front brake disc set - 350.00
front disc pad set - 130.00
TOTAL = 480.00
labour to install the disc and pad - 160.00 (on 21/2/09)
17/1/09
re-setting alarm system - 350.00
29/4/09
connector pipe for coolant - 58.00
coolant hose (rear) - 175.00
labour - 85.00
TOTAL = 318.00
10/6/09
(labour) oil filter housing gasket & O ring - 90.00
gasket - 28.00
2 pcs O ring - 20.00
1 pcs belt - 70.00
TOTAL = 208.00
06/07/09
re-spray 16' rims 4pcs - 200.00
11/07/09 (87,500km service)
oil filter - 45.00
labour - 45.00
TOTAL = 90.00
01/08/09
labour - 60.00
fr lh window lifter - 430.00
TOTAL = 490.00
06/08/09
fr h7 lamp bulb - 38.00
15/08/09
205/55/zr16 michelin pp2 4 pcs - 1,688.00
steel valves 4 pcs - 48.00
balancing, alignment, camber - 143.00
TOTAL = 1,886.15 (plus tax)
18/01/10 (100,000km service)
1 pcs oil filter - 45.00
4 pcs bosch spark plug - 140.00
2 pairs brake pad (front & rear) - 370.00
2 pcs brake sensors - 76.00
oil service - 45.00 (oil self-supplied)
labour - 260.00
TOTAL = 936.00
05/02/10
top up air-cond gas - 50.00
02/03/10
1 pc front emblem - 52.00
2 pcs grommet for emblem - 6.00
TOTAL = 58.00
13/04/10
front R/H window lifter - 430.00
labour - 80.00
TOTAL = 510.00
20/04/10
ignition coil - 520.00
diagnose engine misfire & labour - 60.00
TOTAL = 580.00
03/05/10
air vent valve - 185.00
labour - 45.00
TOTAL = 230.00
18/05/10
air filter - 38.00
microfilter - 65.00
(self installed)
TOTAL = 103.00
12/06/10
alignment + balancing = 183.75
Great works, bro :top: for taking the trouble to list out all your repair works since 2007 to share with others :wink:Btw, where did you service your car especially changing ATF oil. Thinking of changing mine.
i go to 3 places..... one each at the following places:
bandar sunway, ara damansara & usj
i use Ravenol for my engine oil and transmission oil for my GM E46 320i gear box...ATF oil change for 6 litres plus changes to all seals, RM1,150 plus labor...
Latest 'damage'... got weird sound from the front tire... found out the right lower arm ball joints loose..
Now changing
1 set lower arm left-right RM600x2
1 set lower arm bush left-right RM350
labor RM80
TOTAL RM1630
Got gearbox leaking... I wonder how much the cost? Will claim warranty instead for this damage
Where did you do the oil change and the oil seals bro?
My ride just got out from workshop this afternoon...since yesterday... -Warranty claim
-Change oil seal (gearbox) bcoz got leaking
-Change radiator hose due to leaking also
Total damage: RM0.00 but patah kaki for two days...
johnj;532496 said:
Btw, car is perfect now without a single noise!
Yo johnj,
If you don't mind, the lower arm you've got, is it original BMW product?
xUUa;542413 said:
Yo johnj,
Yes I think so cos I specifically told the mech to change ori parts
oh.. thanks for the reply.. damned i changed my OEM lower arm 1 pc for 650 and bush for 350.. so needed to change both L and R = 2000 squeezed already.
i think my rear brake discs are due for change.. recommendation, anyone?
Water hose outlet ori (for car comes with winter package it's longer) = RM200
Expansion Tank original = RM270
Left is the old one
Toyota coolant (suitable for aluminium radiator) = RM20
Changed my tail lights unit (the ones attach to the boot only) left and right = RM287each x 2 = RM584 inclusive installation (not sure cheap or not)
OEM Made in Germany
Car wash = RM10 :p
OEM Made in Germany
Car wash = RM10 :p
beli kat ne bro?
Finally ignition coil 3 & 6 on my M54 failed. I had put in 2 used FOC Bremi to replace the Bosch 3 & 5 about 9 months back, ok for used ones. Morning start up is so much smoother now. Have not got the bill yet but it is less than RM800 for 6 brand new Bosch coils. Feel a little improvement in low end torque, should improve my miserable FC too.
M-SPEED (USJ) - 23.7.2010
1. OIL (CASTROL EDGE) + OIL FILTER (MAHLE) + LABOUR = RM220
2. FR BRAKE PADS (BMW OEM - TEXTAR) + LABOUR = RM160
Next
1. Rear Absober + Front Absober + labour = RM1600 (Is it ok with this price??)
2. Lower Arm + labour = RM 1k each (Is it ok with this price?? seems bit expensive to me):stupid:
4/6/07:
16/6/07:
4 pcs plug - 140.00
wash - 20.00
TOTAL= 1,538.50
14/7/07:
18/8/07:
alignment - 37.50
4 valves - 20.00
TOTAL = 1,117.50
10/9/07
TOTAL = 2,770.00
19/10/07
top hose - 140.00
12/12/07
31/12/07
alignment - 50.00
18/2/08
22/3/08
TOTAL = 425.00
31/3/08
5/4/08
17/5/08
2/7/08
labour - 120.00
TOTAL = 791.00
27/8/08
TOTAL = 810.00
oil filter - 28.00
labour - 35.00
TOTAL = 63.00
31/12/08
TOTAL = 480.00
17/1/09
29/4/09
labour - 85.00
TOTAL = 318.00
10/6/09
gasket - 28.00
1 pcs belt - 70.00
TOTAL = 208.00
06/07/09
oil filter - 45.00
labour - 45.00
TOTAL = 90.00
01/08/09
labour - 60.00
TOTAL = 490.00
06/08/09
15/08/09
labour - 260.00
TOTAL = 936.00
05/02/10
02/03/10
TOTAL = 58.00
13/04/10
labour - 80.00
TOTAL = 510.00
20/04/10
TOTAL = 580.00
03/05/10
labour - 45.00
TOTAL = 230.00
18/05/10
air filter - 38.00
microfilter - 65.00
(self installed)
TOTAL = 103.00
12/06/10
17/06/10
front right hand bumper bracket = 130.00
03/07/10 (112,500km service)
engine oil - 209.00
oil filter - 45.00
rear left wheel bearing - 135.00
brake fluid - 38.00
labour - 305.00
TOTAL = 732.00
12/07/10
alignment - 131.25
QD250;545977 said:
4/6/07:
16/6/07:
4 pcs plug - 140.00
wash - 20.00
TOTAL= 1,538.50
14/7/07:
18/8/07:
alignment - 37.50
4 valves - 20.00
TOTAL = 1,117.50
10/9/07
TOTAL = 2,770.00
19/10/07
top hose - 140.00
12/12/07
31/12/07
alignment - 50.00
18/2/08
22/3/08
TOTAL = 425.00
31/3/08
5/4/08
17/5/08
2/7/08
labour - 120.00
TOTAL = 791.00
27/8/08
TOTAL = 810.00
oil filter - 28.00
labour - 35.00
TOTAL = 63.00
31/12/08
TOTAL = 480.00
17/1/09
29/4/09
labour - 85.00
TOTAL = 318.00
10/6/09
gasket - 28.00
1 pcs belt - 70.00
TOTAL = 208.00
06/07/09
oil filter - 45.00
labour - 45.00
TOTAL = 90.00
01/08/09
labour - 60.00
TOTAL = 490.00
06/08/09
15/08/09
labour - 260.00
TOTAL = 936.00
05/02/10
02/03/10
TOTAL = 58.00
13/04/10
labour - 80.00
TOTAL = 510.00
20/04/10
TOTAL = 580.00
03/05/10
labour - 45.00
TOTAL = 230.00
18/05/10
air filter - 38.00
microfilter - 65.00
(self installed)
TOTAL = 103.00
12/06/10
17/06/10
engine oil - 209.00
oil filter - 45.00
brake fluid - 38.00
labour - 305.00
TOTAL = 732.00
12/07/10
alignment - 131.25
wow..wow.. so expensive the alignment hoo...
My damage today (E46 325i):
Items
RM
Air Filter 68
hose clip (6pcs) 24
fuel hose (6inch) 18
fuel filter with regulator 185
spark plugs platinum (6pcs) 270
Front Brake Pads - 1 Pair 195
front brake sensor 40
Labour Charge 125
Total Damage 925
There are a few more items to be replaced in the next trip:
Gearbox mounting, adjuster (DISA), some bushes, atf change, ..etc:eek:
Items
RM
Air Filter 68
hose clip (6pcs) 24
Labour Charge 125
Total Damage 925
Bro, what is your mileage ? Your DISA shot already ! is it making rattling sound ?
