4/6/07:
took delivery of my E46 318i M43
16/6/07:
Cobra alarm system (metalink) - RM1650
30/6/07: (25,000 km service)
5 ltr engine oil - 112.50
1 pcs oil filter - 35.00
4 pcs plug - 140.00
1 pcs air cond micro filter - 98.00
1 pcs fuel filter - 88.00
1 pcs auto filter (atf) - 125.00
1 pcs auto gasket (atf) - 55.00
1 set front disc pad - 175.00
1 pcs front disc pad sensor - 45.00
7 ltr atf oil (ori) - 455.00
radiator coolant - 30.00
labour (for major service) - 160.00
wash - 20.00
TOTAL= 1,538.50
14/7/07:
power window rear left - 370.00
18/8/07:
alignment - 37.50
4 valves - 20.00
4 michelin xm1 205/60r15 - 1060.00
TOTAL = 1,117.50
10/9/07
vkool elite & v40 - 2600.00
1 set crystal no plate & casing - 170.00
TOTAL = 2,770.00
19/10/07
repair 7" crackline - 200.00
27/10/07 (37,500 km service)
4ltr engine oil fully synthetic & oil filter - 190.00
top hose - 140.00
expansion tank - 300.00
TOTAL = 630.00 (including labour)
12/12/07
3 lightbulbs (rear) - 15.00
31/12/07
front brakepad (ate) - 160.00
front lower arm bush - 350.00
alignment - 50.00
adjust rear camber - 50.00
off wheel balancing - 32.00
on wheel balancing - 16.00
TOTAL = 665.40 (plus tax & labour)
18/2/08
1 h7 headbulb - 28.00
22/3/08 (50,000 km service)
oil filter + 4ltr engine oil + labour - 190.00
22/3/08
bought @ inner power
rear ate disc pad - 115.00
rear brembo brake disc set - 310.00
TOTAL = 425.00
labour charge to change rear brake pad & brake disc - 70.00 (on 1/4/08)
31/3/08
alignment & balancing - 155.40 (plus tax & labour)
5/4/08
new alpine ida-x001 ice+speakers - 3,000.00
17/5/08
re-spray right hand side of the car - 600.00
2/7/08
19/7/08 (62,500 km service)
4 ltr mobil 1 engine oil - 198.00
1 set auto filter & gasket - 168.00
6 ltr ori auto oil (atf) - 270.00
labour - 120.00
TOTAL = 791.00
27/8/08
1 pcs radiator assy - 750.00 (plus labour)
3 ltr coolant - 60.00
TOTAL = 810.00
30/12/08 (75,000 km service)
oil filter - 28.00
labour - 35.00
TOTAL = 63.00
31/12/08
alignment & balancing - 181.65 (plus tax & labour)
2/1/09 (yet to be installed)
brembo front brake disc set - 350.00
front disc pad set - 130.00
TOTAL = 480.00
labour to install the disc and pad - 160.00 (on 21/2/09)
17/1/09
re-setting alarm system - 350.00
29/4/09
connector pipe for coolant - 58.00
coolant hose (rear) - 175.00
labour - 85.00
TOTAL = 318.00
10/6/09
(labour) oil filter housing gasket & O ring - 90.00
gasket - 28.00
2 pcs O ring - 20.00
1 pcs belt - 70.00
TOTAL = 208.00
06/07/09
re-spray 16' rims 4pcs - 200.00
11/07/09 (87,500km service)
oil filter - 45.00
labour - 45.00
TOTAL = 90.00
01/08/09
labour - 60.00
fr lh window lifter - 430.00
TOTAL = 490.00
06/08/09
fr h7 lamp bulb - 38.00
15/08/09
205/55/zr16 michelin pp2 4 pcs - 1,688.00
steel valves 4 pcs - 48.00
balancing, alignment, camber - 143.00
TOTAL = 1,886.15 (plus tax)
18/01/10 (100,000km service)
1 pcs oil filter - 45.00
4 pcs bosch spark plug - 140.00
2 pairs brake pad (front & rear) - 370.00
2 pcs brake sensors - 76.00
oil service - 45.00 (oil self-supplied)
labour - 260.00
TOTAL = 936.00
05/02/10
top up air-cond gas - 50.00
02/03/10
1 pc front emblem - 52.00
2 pcs grommet for emblem - 6.00
TOTAL = 58.00
13/04/10
front R/H window lifter - 430.00
labour - 80.00
TOTAL = 510.00
20/04/10
ignition coil - 520.00
diagnose engine misfire & labour - 60.00
TOTAL = 580.00
