E46 parts & maintenance
Water level always low
Water level always low. Found that the expension tank got pinhole size hole.
Damage:
1. Expension Tank = RM 270 + Labour
2. Water hose (Long with 3 output) = RM350 + labour
Total damage : RM620
Now my pocket got leak...
Brake Pad replace.
Juz replace front brake pad at Chu Seng, Penang. Here the cost below.
1 set of front brake pad(ori) = $350.00
1 pc of brake pad sensor = $58.00
Labour = $45.00
Total = $453.00
Brake Servo Pump 2 x failure within 8 month
16 November 2009 - BRAKE SERVO PUMP FAILURE
Cost : RM1400 (Labour charge FOC, Brake Fluid FOC)
15 May 2010 - BRAKE SERVO PUMP FAILURE....AGAIN!!!!
Cost : RM1400 AGAIN!!!
The mechanics told me that he HARDLY found this problem as this is a rare case. But somehow my BAD LUCK with the servo pump seems to continue on. :(
I tried to ask for guarantee but he told me no warranty whatsoever for all parts. In the end i have to bear all the cost...TWICE!!! herghh...
Anybody been in the same situation? Fix...use...few month same problem occur. How come they dont have any warranty? I wonder. What should I do?
Is it original BMW parts?
Maintenance
10/06/2010 - Benzone Auto Car Care
Oil change package (Castrol Magnatac 4litres 10W40, Filter, Labour) - RM158.00
Oil System Cleaner - RM80.00
Engine Oil 1 litre ( Castrol Magnatac) - RM 38.00
Labour for throttle body cleaning - RM85.00
Total Damage - RM361.00
Tax 5% - RM4.25
Total Damage after Tax - RM365.25
After cleaning the throttle body, the RPM needle fluctuate less, stepping on the pedal feels like stepping on tofu:69:, better throttle response.:rock:
BMW logo
Last 2 weekend drove my E46 a bit high speed. Suddenly my front logo flown away. Couldnt stop to get it in the midle of NKVE highway.
Went to Stutgart Taman Mayang bought the front BMW logo for RM40 . Not ori.
If your Brake Servo Failure again. Then go to Auto Bavaria to get it rectified, pay premium price and they will warranty 1-2 years.
here's mine
changed coolant tank rm 290, radiator coolant rm 35 , arm rest change rm 80, second hand arm rest e46 rm 600 labor charges rm 80 . total = rm 1085.00 .
last year i had spent 3k++ in total for maintenance only , this year up till june , i'm almost reaching that figure already , sometimes i wonder whether its really worth it to keep maintaining this almost 10 yr old car than getting a new and or cheaper one.the only advantage i have is theres no outstanding car loan on my baby.hmm..
My e46 repair bill at heritage!
1) Rear Absorber Mounting @ 35 x 2 = 70.00
2) Rear Absorber Damper@30x2 = 60.00
3) Used Long Shaft = 2000.00 ( Due to humming noise around 80 above KMh )
4) Lower Arm Bush 1 set - 695.00
5) Front Absorber ( Boge ) @385x2 = 770.00
6) Front Absorber Damper @ 25x2 = 50.00
7) Front Absorber Mounting @80x2= 160.00
8) Front Brake Pads 1 Set - 280.00
9) Lower Arm @ 555x2 = 1110.00
10 Workmanship -= 400.00
Total..= 5615.00 with rm20 Serv tax.
Please dont ask me why I went there and didn't go here or anywhere else!!hehehe
Damage for today....
Car seems to be jerking and when idle the engine like shaking. After checking with computer found that 2 ignition coil already kaput. Changed with new one Bosh...damage as below.
2 Unit Ignition Coil 2 x RM 195
Labor 1 x RM 45
Total RM 435
Now car already ok and engine seems to be smooth then before.
Lower arm for RM530 per piece at new place in sunway...autobahn...great personal service...
I wonder where is this Mspeed USJ workshop location? Anyone can give me direction? I work in USJ7.
Also Benson SS2... he he he
Just use the search function in the forum to find the location of Mspeed at USJ. Some bros have already done a good write up about their location so no point repeating here. Tel: 03-56311911
As for Benson Auto, its the middle shop along the same row as Wo Lai Ye dried meat. You won't miss it as there is only one workshop there. Near the shop with a big duck hanging as their advertisement board. Tel: 03-78737113 :wink:
Yup great service.. Tan is ex mchanic from M-roadster pandan indah. Just try service at his shop.. nice buddy..quite reasonable price also..
kayz;464438 said:
If you in Pandan Indah, can try MRoadster at Pandan Mewah, same row with acc. shop
I had extremely bad experience with MRoadster. Their pretense of good attitude can change 180 degrees drastically into nasty rascals the moment they make some technical faults. There were some other complaint threads on them a few years ago.
Would not recommend this place to anyone.
After 3 weeks waiting in line at last my car has been checked and damage so far was:
1.Changing left lower arm bush - RM 160
2. Replacing washer pump (for windshield) - RM 120
3. Washer pump seal- RM 10
4. Crank case -ventilation valve - RM 230
5. 0il pan gasket - RM 105
6. Oil filter - RM 30
7. Oil filter housing gasket - RM 60
8. Castrol Edge 5-40w engine oil - RM 198
9. Pumping out used bush - RM 20
10. Workmanship - RM 230
All together: RM 1163
Done at Menglembu Ipoh,Perak
Got my ride yesterday.. ask my mechanic to chk thoroughly (using the handheld thingy)... found a camshaft sensor error that cannot be removed.. he ask me to drive in a long trip this weekend to 'confirm' the problem. I have to bring back my car to him to re-diagnose next week...
Total cost RM100
lower arm
Lower arm for RM530 per piece at new place tin sunway...autobahn...great personal service...
Just bought my E46 320i LH Lower arm + bush (Vaico) 2 days ago rm 325 + rm 85
