E46 parts & maintenance
Had did my service today.
Normal Service
1. 5 Liter Revenol 5/40w
2. Oil Filter
3. Labor (Reset computer and Oil change)
Total = RM 290
Front Bearing
1. 2 Unit front bearing for Left and Right
2. Labor
Total = RM500
at gear oil transmission
just changed AT oil RM413-00.
now smoother and happier car.
Normal Service
2. Oil Filter
Total = RM 290
Front Bearing
2. Labor
Total = RM500
How is the Revenol oil ... Any good? Where is the place you did your oil change bro?
Dear All Sifu,
Just buy my first european ride BMW....feel happy and great, but it's doubts I have can anybody can help to solve?
My ride spec:
Registed year 2002/2007
731504 Mileage
E46 320i Msports
2.2
6cyclinder
I do searching the forums....I realise that bmw got a lot of spec...perhaps some I also didn't know about it.......
What is the diff non M and M? (I do seaching forum tell me that all about the interior cockpit, suspension, and biggest rims....that's all?)
So 6 cyclinder easy to maintain? Cause just newbie from local car to euro car....hehehehe.
Please.....help Sifu....thx
Latest "damage" on the e46 325i ....
1) Front brake discs - ori RM330 a pc.
2) Fan belt RM115
3) Starter (used from chop shop) RM380
Symptoms of the starter solenoid on the way out - clicking sound when you turn the ignition, but no cranking. Sounds a bit like a weak battery, but if your lights remain bright, it's definitely not the batt.
totoro;400288 said:
changed fuel filter:
2 new hose clips
RM63-00 + RM10-00 + labour = RM83-00
mr totoro,
what model is ur UDM?pardon me for asking bcoz i get different price from this forum,someone quote +- rm200,some say +-160,and u ar the cheapest.plan to change fuel filter too,mine is e46 325i,can get at ur price?thanks
Revenol quite nice...smooth engine. You should try...it's a German oil..Changed it at my usual mach...at subang...k&s auto
Mat Kay;402483 said:
Who's Vassu... have u got better price?
Haven't change yet...but Vassu quoted RM2700 ASC ECU + ABS Pump (Second Hand Unit). and 1k for the ASC ECU only (Second hand also) if I not mistaken. But better check with him.
Damage on my wallet
done on 28/02/2009
Vent Hose..............rm76
oil filter.....................40
fuel injection cleaner.....60
engine flush...............60
nut..........................13
windscreen cleaner........8
rubber boot kit..........150
contact socket...........28.40
temperature sensor....185
helix ultra..............383
wheel allignment.......40
labour.................75
total.........1128.35
Dear gentlemen,
FYI, I driving a pre-face lift e46 & would to convert to face Lift ...... do you guys know if I would like to change it where should i refer to & roughly how much it will be ?
I did replaced in new rear lamp set as 04 model ..... any possiblility to only change the side maket without changeing to front lamp set & bornet due both of them are brand new ?????
Facelifting the older models doesn't only involve changing the signal lamps. You need to change the head lamps, hood, fenders, etc as well.
NEW GUY;406739 said:
Dear gentlemen,
u posted in the wrong tread, anyway pm NKTOB for facelift info coz he done his for less than 3k. like DolCeAddicT mention, u need to change your headlamp, side signal, marker, fender and bonnet, change your bumper as well. sell off your lamp & bonnet
sifus,
Thinking of upgrade fr current e36 to e46. Tend to get a 328 instead of 325...can any sifu tell me hows d maintenance of 328 compare to 325? Will it b very xpensive?
servis my UDM
Radiator pipe connector 1pcs rm 98.00
pan gasket / gasket ATF 1pcs rm 55.00
Fl Strainer /filter ATF 1pcs rm 85.00
shaft seal /oil seal top convertor 1pcs rm 135.00
Gearbox oil varco 6 btl rm 372.00
Gearbox oil ZF lifeguard 1 btl rm 85.00
upah kerja + lube rm 480.00
engin oil top 1 sytck 10-40 1 btl rm 120.00
oil fiter 1pcs rm 45.00
air cnd fiter 1pcs rm 140.00
diagnsis cmputer 1 job rm 60.00
total rm 1675.00
rm -75.00
rm 1600.00
murah ke mahal?
My History
4/6/07:
took delivery of my E46 318i M43
16/6/07:
Cobra alarm system (metalink) - RM1650
30/6/07: (25,000 km service)
5 ltr engine oil - 112.50
1 pcs oil filter - 35.00
4 pcs plug - 140.00
1 pcs air cond micro filter - 98.00
1 pcs fuel filter - 88.00
1 pcs auto filter (atf) - 125.00
1 pcs auto gasket (atf) - 55.00
1 set front disc pad - 175.00
1 pcs front disc pad sensor - 45.00
7 ltr atf oil (ori) - 455.00
radiator coolant - 30.00
labour (for major service) - 160.00
wash - 20.00
TOTAL= 1,538.50
14/7/07:
power window rear left - 370.00
18/8/07:
alignment - 37.50
4 valves - 20.00
4 michelin xm1 205/60r15 - 1060.00
TOTAL = 1,117.50
10/9/07
vkool elite & v40 - 2600.00
1 set crystal no plate & casing - 170.00
TOTAL = 2,770.00
19/10/07
repair 7" crackline - 200.00
27/10/07 (37,500 km service)
4ltr engine oil fully synthetic & oil filter - 190.00
top hose - 140.00
expansion tank - 300.00
TOTAL = 630.00 (including labour)
12/12/07
3 lightbulbs (rear) - 15.00
31/12/07
front brakepad (ate) - 160.00
front lower arm bush - 350.00
alignment - 50.00
adjust rear camber - 50.00
off wheel balancing - 32.00
on wheel balancing - 16.00
TOTAL = 665.40 (plus tax & labour)
18/2/08
1 h7 headbulb - 28.00
22/3/08 (50,000 km service)
oil filter + 4ltr engine oil + labour - 190.00
22/3/08
bought @ inner power
rear ate disc pad - 115.00
rear brembo brake disc set - 310.00
TOTAL = 425.00
labour charge to change rear brake pad & brake disc - 70.00 (on 1/4/08)
31/3/08
alignment & balancing - 155.40 (plus tax & labour)
5/4/08
new alpine ida-x001 ice+speakers - 3,000.00
17/5/08
re-spray right hand side of the car - 600.00
2/7/08
19/7/08 (62,500 km service)
4 ltr mobil 1 engine oil - 198.00
1 set auto filter & gasket - 168.00
6 ltr ori auto oil (atf) - 270.00
labour - 120.00
TOTAL = 791.00
27/8/08
1 pcs radiator assy - 750.00 (plus labour)
3 ltr coolant - 60.00
TOTAL = 810.00
30/12/08 (75,000 km service)
oil filter - 28.00
labour - 35.00
TOTAL = 63.00
31/12/08
alignment & balancing - 181.65 (plus tax & labour)
2/1/09 (yet to be installed)
brembo front brake disc set - 350.00
front disc pad set - 130.00
TOTAL = 480.00
labour to install the disc and pad - 160.00 (on 21/2/09)
17/1/09
re-setting alarm system - 350.00
29/4/09
connector pipe for coolant - 58.00
coolant hose (rear) - 175.00
labour - 85.00
TOTAL = 318.00
10/6/09
(labour) oil filter housing gasket & O ring - 90.00
gasket - 28.00
2 pcs O ring - 20.00
1 pcs belt - 70.00
TOTAL = 208.00
