koryong
- Dec 5, 2004
- 419
- 18
erica34;368214 said:Esso LT 71141. Might switch to Redline D4-ATF the next change.
I guess these are the specified oils for your transmission - 325ci M54 right ?
koryong;368475 said:Latest maintenance on the e46 325i ...
1) Front absorbers (Bilstein) @ RM300 x 2
2) Front absorber mounting (Lemforder) @ RM80 x 2
3) Front absorber damper @ RM25 x 2
4) Front upper & lower spring pads @ RM35 x 4
5) M-Tech springs (used) @ RM330 / set :top:
6) Rear upper& lower spring pads @ RM25 x 4
7) Labor RM320
Ride is lowered marginally by half inch, but great fun sweeping corners now ... :wink:
7) Labor RM320
Blue_toyz;369436 said:If ur mech have other used sport spring for sale just let me know.
i also plan to lowered a bit my e46.:top:
OldmanBM;370895 said:My contribution to this Thread.
e46 year 99/2000, 105K km on odometer.Non trip tronic
Sudden gear slips experience. Few days later, total lost of trasmission.
Gear box had to be fully rebuild. Took 5 days. Major parts changed are the full gearbox repair kit,used gearbox main casing ( with vertical gear/steps outer ) , washers and gaskets, filter , oils and a huge chunk of workmanship.
The number of parts changed came to about 30 plus pcs !
TOTAL COST : RM 3800 +
FYI, the few pcs of clutch plates have not reached EOL yet bt the physical damage is a crude 3 in diameter steel cup plate with all its sides grinded sharp. Few pcs of pressure spings were bent sideways.
Did not expect such failure in an E46 which is for family use and low milage.
Question is, am I the isolated case or there are others who had simular experience.
OldmanBM
william.cts;376326 said:Hi All,
I have just purchased a 325i, yr 02. After test driving the car... i acknowledge a high weasel sound when i press the accelerator hard... is it normal??? It is quite clear from outside the car..
Can anyone give me some suggestion... and i am new to this thread...
thanks...
thanks...
rizaljai;380287 said:Done on 13th Dec 2008: (318 1.9)
1. Engine oil, semi, oil filter - 150
2. Rear brake pads (Jurid) - 140
3. Front left wheel bearing - 250
4. Air filter - 50
5. Fuel filter - 70
Total - 660
