E46 parts & maintenance
william.cts;376326 said:
Hi All,
I have just purchased a 325i, yr 02. After test driving the car... i acknowledge a high weasel sound when i press the accelerator hard... is it normal??? It is quite clear from outside the car..
Can anyone give me some suggestion... and i am new to this thread...
thanks...
I had the same problem not to long ago...u might want to check your power steering pump or belt tensioner...get a long screw driver and press it to check which is giving the vibration...
04-Oct-08:
Radiator - rm795
Expansion tank - rm295
Radiator panel - rm248
Thermostat - rm245
Labour - rm100
Total: rm1685
28-Oct-08:
2pc engine mounting - rm390
2pc gearbox mounting - rm136
Longshaft coupling - rm145
10 liters gearbox oil - rm680
Gearbox filter and gasket - rm210
2pc side rod boot - rm96
Labour - rm300
Total: rm1957
(update)
Key from Auto Bavaria: rm918.84 + rm30
28-Oct-08:
4pc Hankook S1-Evo K107 - rm2400
Labour - rm20
Total: rm2420
12-Dec-08:
Electric fan (ori BMW) & labour - rm1500
Fan belt tensioner - rm195
Left plastic cover - rm195
Labour - rm100
Total: rm1990
Brought own Redline differential oil (from N1-racing) - rm50 per bottle*
*after discount since also purchased 12 bottles D4 ATF
29-Dec-08:
Idle valve & labour - rm750
Total: rm750
heyya, this is for 320i... 27th december 2008, DID IT AT BMW ULTIMATE MOTORSPORT (SPECIALIST) at Batu Caves
Spark plug RM45 (6)= RM270
Oil filter = RM38
Micro filter= RM110
Fan belt= RM90
Belting A/C= RM75
Thermostat= RM220
Deflect pulley= RM95
Tensioner ASSY=RM165
Tensioner ASSY (Rear)= RM170
BMW Coolant 1 botol= RM45
Bracket set with rubber mounting= RM330
Oil strainer= RM98
Auto oil pan gasket= RM80
Brake fluid= RM48
ATF1L RM65 (6 botol)= RM390
Bulb 12V/21W RM6 (2 rear)= RM12
Shell Helix Ultra 5w-40 (4L)= RM290
Shell Helix Ultra 5w-40 (1L) RM58 (3)= RM174
Labour= RM260
Service tax= RM13
All= RM2892...phew
p/s: ada lagi bil but due in weeks time, these services are only one-off (not for the next 100k km), this BMW speacialist is good, THEY KNOW what they are doing...thumbs up...
pengajaran: servis la kereta anda,kalau tidak, jadila macam saya
My History
4/6/07:
took delivery of my E46 318i M43
16/6/07:
Cobra alarm system (metalink) - RM1650
30/6/07: (25,000 km service)
5 ltr engine oil - 112.50
1 pcs oil filter - 35.00
4 pcs plug - 140.00
1 pcs air cond micro filter - 98.00
1 pcs fuel filter - 88.00
1 pcs auto filter (atf) - 125.00
1 pcs auto gasket (atf) - 55.00
1 set front disc pad - 175.00
1 pcs front disc pad sensor - 45.00
7 ltr atf oil (ori) - 455.00
radiator coolant - 30.00
labour (for major service) - 160.00
wash - 20.00
TOTAL= 1,538.50
14/7/07:
power window rear left - 370.00
18/8/07:
alignment - 37.50
4 valves - 20.00
4 michelin xm1 205/60r15 - 1060.00
TOTAL = 1,117.50
10/9/07
vkool elite & v40 - 2600.00
1 set crystal no plate & casing - 170.00
TOTAL = 2,770.00
19/10/07
repair 7" crackline - 200.00
27/10/07 (37,500 km service)
4ltr engine oil fully synthetic & oil filter - 190.00
top hose - 140.00
expansion tank - 300.00
TOTAL = 630.00 (including labour)
12/12/07
3 lightbulbs (rear) - 15.00
31/12/07
front brakepad (ate) - 160.00
front lower arm bush - 350.00
alignment - 50.00
adjust rear camber - 50.00
off wheel balancing - 32.00
on wheel balancing - 16.00
TOTAL = 665.40 (plus tax & labour)
18/2/08
1 h7 headbulb - 28.00
22/3/08 (50,000 km service)
oil filter + 4ltr engine oil + labour - 190.00
22/3/08
bought @ inner power
rear ate disc pad - 115.00
rear brembo brake disc set - 310.00
TOTAL = 425.00
labour charge to change rear brake pad & brake disc - 70.00 (on 1/4/08)
31/3/08
alignment & balancing - 155.40 (plus tax & labour)
5/4/08
new alpine ida-x001 ice+speakers - 3,000.00
17/5/08
re-spray right hand side of the car - 600.00
2/7/08
19/7/08 (62,500 km service)
4 ltr mobil 1 engine oil - 198.00
1 set auto filter & gasket - 168.00
6 ltr ori auto oil (atf) - 270.00
labour - 120.00
TOTAL = 791.00
27/8/08
1 pcs radiator assy - 750.00 (plus labour)
3 ltr coolant - 60.00
TOTAL = 810.00
30/12/08 (75,000 km service)
oil filter - 28.00
labour - 35.00
TOTAL = 63.00
31/12/08
alignment & balancing - 181.65 (plus tax & labour)
2/1/09 (yet to be installed)
brembo front brake disc set - 350.00
front disc pad set - 130.00
TOTAL = 480.00
17/1/09
re-setting alarm system - 350.00
all these cost of maintaining ------if got no spare cash, will become 'KES SAKIT JIWA'.
e46 318 2.0
engine oil ( semi sinthetics) + oil filter = 193
air filter = 50
spark plug = 130
front brake pad (jurid) = 130
labour charges = 100
total = 603
hi ,bro did any one replaced the air filter k & n , did k & n air filter has difference performance and fuel consumption?
4ltr Havoline 5w-30 Full Synthetic x 2 = rm380
Oil filter = rm35
Oil service reset and labour = rm65
Total damage =rm480
Good oil ... can feel the engine revving smoother and lighter.
yes maintaining a bmw is expensive and very costly if parts have to be changed.
Mat Kay;399318 said:
Hi all, how much ABS module (ASC) for 2.0 318i cost? Mine gor problem...plz help
I also got the same problem. Ingress Auto 5.7K ...normal shop 3.7k half cut 2.7k I still didn't change yet...
changed fuel filter:
2 new hose clips
RM63-00 + RM10-00 + labour = RM83-00
kshapawi,
Ah Meng quoted less than RM3500 with warranty. Still not changed yet. According to him u cannot change to 2nd hand unit.... not sure why. Got another workshop quoted approx RM3800 in Shah Alam. Went to AB ... that unit list price 3600. Tell me bro if u can get better price elsewhere.
Oil filter = rm35
Total damage =rm480
havoline... :top:
As usual did at MSPPED
16/02/09
1.Altenator,labour and reset = RM1400
2.Boot pressure spring = RM130
TOTAL = RM1900
26/02/09
1 pc vent pipe
1 pc vent hose
1 pc pressure valve
1 pc vent pipe
1 pc vent pipe,return pipe & labour
TOTAL = RM800
28/02/09
Update software DME & EGS gearbox
TOTAL =RM200
May I know how much the ori ATF from Auto Bavaria will cost us? is it 1litre~Rm180?
Mat Kay;400848 said:
kshapawi,
Maybe can try to find Vassu...
