E46 parts & maintenance
serviced my car today.
check in @ DTM Automotive 11.00am
worksheet prepared last nite by owner,so they are expecting me.
1 x 5 series on service
2 x 3 series (including mine)
a few mercedes
one or two korean make...in and out for minor checks...
petronas syntium fully synthetic 4 litre x 2 = rm358
oil filter x 1 = rm35
gear oil checked = foc
air filter = rm75
lower arm bush x 2 = rm270
press bush(?) x 2 = rm20
alignment = rm15
labour for servicing = rm25
labour lower arm bush = rm120
link rod (fr) = rm95
full computer diagnose = rm80
TOTAL =rm1093...
next visit (not enough time to do today...):
lower arm - 1 pair (rm560 x2)
engine oil sump gasket...}
steering rack (leaking)....}anybody got any idea how much are these...?
check out 6.00pm...
tq...
steering rack try the repair kit 1st it cost abt Rm450+ (No Guarantee)
recon cost about 1k need to trade in urs
change a set will cost abt almost 3k not sure exact price
my normal service. 28-7-2008
Castrol Edge Sport -- RM150
Oil filter/general check up/mileage reset/labour -- RM52-00
(including tax)
Penang.
driving to kerteh this week, so went to mspeed to do some checkups and below are the damage.
Water Pump - RM 480.00
Thermostat - RM 190.00
Coolant - RM 30.00
Engine Mouting - RM 380.00
Lower Arm Bush - RM 350.00
ExpansionTank - RM 280.00
Timing Sensor - RM 350.00
Absorber (F) BOGE - RM 800.00
Absorber Mounting - RM 200.00
Absorber Damper - RM 70.00
DISA Valve - RM 680.00
Fuel Pump - RM 520.00
total damage : 4300.00 (after 30 bucks discount)
After that bought 4 new set of Michelin MXV8 + Alignments, another damage of RM 1700. let's see how it goes on the highway tomorrow.
gonna eat maggee everyday in terengganu
Hi Guys, my son bought a 318i E46 a few months ago and he left for overseas. I am now not too sure about the service timing and mileage. He used synthetic oil for the serice before he left and I am not sure which workshop. Anyone can assist?
1. Any recommendations on workshops (reasonable la - I am staying around Hartamas/Mont Kiara area)
2. How many KM intervals before we need to service? Some told me 10K some said 25K.. I am not sure now.
My other son would like to buy a 318ci year 2000. Is it advisable with 1.9 engine?
Thanks
(including tax)
Penang.
Hi totoro,
Do you know the best place to fix air cond in penang?
Bix;313112 said:
Check all the pipes for any leakages. Don't forget the ABS pump and its sensors.
Bix
P/S Based on my negative experience.
i think i got the same problem now..
the pipes leakages, sensors..
never go to any workshop/services yet
what should i do first..?
p/s: bix, mind to share ur experience..
Hi nurul,
I think what I meant with this statement is in response to kshapawi's post of buying a new car with only 3 weeks warranty.
I had a warranty on my car and it was for three months from the date of purchase but I took it for granted and didn't send for a check up within that period of time.
It's good to send to another workshop immediately after receiving the car from the dealer, as you are able to rectify any faults with the car. Plus, having a warranty is also a bonus.
As for yours, do you have a warranty? If you do, then you should send to other BMW specialised workshop and inspect the whole car. One of the most expensive items to replace is the ABS. So, do keep in mind to check that when you're with the mechanic. Once you've inspected the car, go back to the dealer within the warranty period and inform them of the faults to get them replaced. They will want to fix your car with their own mechanics so do watch how they work your car and make sure that they replace the items. Some dealers might also pay directly to your mechanic, after a negotiation.
Hope this helps.
My History
4/6/07:
took delivery of my E46 318i M43
16/6/07:
Cobra alarm system (metalink) - RM1650
30/6/07: (25,000 km service)
5 ltr engine oil - 112.50
1 pcs oil filter - 35.00
4 pcs plug - 140.00
1 pcs air cond micro filter - 98.00
1 pcs fuel filter - 88.00
1 pcs auto filter (atf) - 125.00
1 pcs auto gasket (atf) - 55.00
1 set front disc pad - 175.00
1 pcs front disc pad sensor - 45.00
7 ltr atf oil (ori) - 455.00
radiator coolant - 30.00
labour (for major service) - 160.00
wash - 20.00
TOTAL= 1,538.50
14/7/07:
power window rear left - 370.00
18/8/07:
alignment - 37.50
4 valves - 20.00
4 michelin xm1 205/60r15 - 1060.00
TOTAL = 1,117.50
10/9/07
vkool elite & v40 - 2600.00
1 set crystal no plate & casing - 170.00
TOTAL = 2,770.00
19/10/07
repair 7" crackline - 200.00
27/10/07 (37,500 km service)
4ltr engine oil fully synthetic & oil filter - 190.00
top hose - 140.00
expansion tank - 300.00
TOTAL = 630.00 (including labour)
12/12/07
3 lightbulbs (rear) - 15.00
31/12/07
front brakepad (ate) - 160.00
front lower arm bush - 350.00
alignment - 50.00
adjust rear camber - 50.00
off wheel balancing - 32.00
on wheel balancing - 16.00
TOTAL = 665.40 (plus tax & labour)
18/2/08
1 h7 headbulb - 28.00
22/3/08 (50,000 km service)
oil filter + 4ltr engine oil + labour - 190.00
22/3/08
bought @ inner power
rear ate disc pad - 115.00
rear brembo brake disc set - 310.00
TOTAL = 425.00
labour charge to change rear brake pad & brake disc - 70.00 (on 1/4/08)
31/3/08
alignment & balancing - 155.40 (plus tax & labour)
5/4/08
new alpine ida-x001 ice+speakers - 3,000.00
17/5/08
re-spray right hand side of the car - 600.00
2/7/08
19/7/08 (62,500 km service)
4 ltr mobil 1 engine oil - 198.00
1 set auto filter & gasket - 168.00
6 ltr ori auto oil (atf) - 270.00
labour - 120.00
TOTAL = 791.00
27/8/08
1 pcs radiator assy - 750.00 (plus labour)
3 ltr coolant - 60.00
TOTAL = 810.00
from kelate :
oil filter rm30
front brake pad rm140
rear brake pad rm80
rear power window (without motor) rm145
now maybe should change aircond blower motor rm ? please help how much...
Blew my e46 expansion tank today and decided to do few other things as well:
Expansion tank : RM220.00
Coolant : RM 30.00
Labour : RM 50.00
Did those in the morning, stop at a shop and started the engine suddenly the indicator for malfuntion gearbox appeared together with DSC, ABS & handbrake light
Gearbox oil(6L ZF) : RM288.00
ATF filter : RM 85.00
G/box sump gasket : RM 58.00
Rear diff oil : RM 85.00
Car Diagnose : RM150.00 ( a bit steepla)
Labour : RM 85.00
Total RM 1,059.00. Wheel speed sensor x ganti lagi so DSC, ABS and brake indicator still on. Hopefully only the sensor yg kaput....not ABS pump. Now gear changing is so smooth, first doing it and my mileage is 87k km N42.
Done quite a bit of work since 2007 (for a 330ci E46) Where possible I have included part numbers.
Radiator Over Flow Tank (Just Changed)
Radiator Reserve Tank RM 370
Reserve Tank Themostat RM 380
Radiator Cap RM 95
Top Hose RM 240
For Factory Fitted Air Cond (With Part no)
61 31 8 378 940 Switch RM 74.70
61 35 6 960 141 Module RM 1277
64 11 9 135 744 Evaporator RM 2243
64 11 9 135 745 Valve RM 537.08
64 53 8 377 330 Dryer RM 896.76
General Service (Part no Inc)
11 42 7 512 300 Filter element RM 58.39
83 12 0 404 886 Cleaner (dunno what this is) RM 11.31
83 13 0 139 897 Brake Fluid RM 56.11
99 99 0 000 001 Petronas Syntium ( 6.5L) RM 487.5
12 61 7 508 003 Sensor for engine oil RM 567.68
51 21 8 026 384 Front door Brake (RH) RM 149.83
51 71 8 227 910 sealing (Soft top) RM 308.02
Air Cond Again (another mechanic) No part Nos this time
Blower regulator RM 480
Spark Plug Coils (the things that fit above the spark plug) RM 295
51 13 7 170 965 Boot lid Grip for a CI RM 420
51 14 8 132 375 Plaque RM 89.47
My car was jerking whenever I brake. Changed two bushes for RM600 (inclusive of labour). No issues so far after the repair.
hey3er;278818 said:
hi bro, i m new here. i wanted to check the price of power steering pump for my e46 yr2002 auto bavaria model. any info. tx
Part number ZF 32416758595 Eng Soon Singapore selling SGD450.00 ( MYR1086.00 )
Just spent a big chunk of money on my newly acquired 320 2.2.
Most are replaced due to "insurance" rather than need replacement.
Air filter RM68
AC filter RM135
Water pump (ori) RM495
Coolant tank RM265
Coolant tank thermostat RM245
Thermostat housing RM195
Gear box oil (ori) RM680 (10 liters)
Gear box filter and gasket RM210
Injector cleaner RM42
Windscreen cleaner RM8 (arggghhh!!!)
Coolant Rm28
Fuel filter RM185
Rear axle oil RM48
Fuel hose RM9 (6 pcs)
Hose clip RM24 (6 pcs)
Vacuum hose RM6 (4 inches)
Key case RM116 (2 pcs)
Update EGS, key reset, convenience features re-programming RM280
Labour RM280.
Total RM3319.
*pengsan*
