Hi guys just want to share my service cost for E46 318i M43
year 2001/2005
1.ENG OIL -150.00
2.ATF 1L X 8-560.00(1L 70.00)
3.BRAKE OIL 1L X 2L-100.00
4.COOLANT 1L X 3L-135.00
5.Y PIPE-1PC 95.00
6.LABOUR/DIAGNOSTIC -1500.00
7.RADIATOR GUARD-210.00
8.RADIATOR SERVICE-450.00
9.RADIATOR GUARD PIPE-110.00
10.VLV COVER GASKET-120.00
11.WATER PUMP-195.00
12.WATER PUMP PULLY-175.00
13.GEAR BOX MOUNTING-120.00(2PCS)
14.GEAR BOX SERVICE-1550.00(NO IDEA Y THEY SERVICE )
15.TENTIONER-175.00
16.VENTILATION HOSE-155.00
17.THERMO TANK-185.00
18.THERMOSTAT ENGINE-250.00
19.AIR FILTER-65.00
20.MICRO FILTER-115.00
21.OIL FILTER-30.00
22.OIL FILTER HOUSING GASKET-120.00
23.TIE ROD HAND-390.00(2PCS)
24.TIMING COVER GASKET SET-180.00
25.BLOCK PIPE-65.00
26.FLY WHEEL OIL SEAL-140.00
27.ENGINE MOUNTING-370.00(2PCS)
28.LOWER ARM BUSH-200.00
29.LONG SHAFT MOUNTING-195.00
30.POWER STEERING HOSE(TANK TO PUMP)-260.00
31.POWER STEERING HOSE(TANK TO COOLER)-180.00
32.SPARE TANK-250.00
33.SPARK PLUG-140.00
34.BRAKE PAD REAR-185.00
35.BRAKE PAD FRONT-195.00
36.CRANK SHAFT OIL SEAL-60.00
37.TROTTLE HOSE-155.00
38.STEERING BOOT-90.00
39.STEERING FLUID-60.00
40.STEERING RACK MOUNTING-60.00
41.FUEL FILTER-80.00
42.OUT SIDE TEMP SENSOR SET-165.00
43.AXLE OIL-35.00
44.AXEL BUSH-290.00
TOTAL PRICE RM-10,300.00
PLS TELL ME WHY GOT 2 TANK.....ITEM:32 & 17 IT IS SAME ITEM..
TODAY SEND THE CAR TO POWER BOOSTER REPAIR AIR COND COOLING COIL LEAK QUOTED FOR RM1500.00
TMR WILL COLLECT THE CAR..
