E46 Part and Service Cost II
rwd;814231 said:
Ya sifu, it come with original HID, auto leveling..etc....
sorry for very last 2 questions....
just wonder how is Eagle Eye quality compare with Original headlight?
If after some years, I want to change the headlight lens, Is the original E46 headlight lens fit on Eagle Eye?
Dont la call me sifu.. Ori are of better quality and wont turn yellow after a few years. Also its easier to tell the officer at JPJ roadblock that yours are original not retrofitted. If possible nego to RM1200 la since you can mod the projector lamp for RM700 now.
rwd;814228 said:
..I found a pair of E46 original Xenon light (used)...quoted RM1600..condition = half cut....is that a good price?
That is what the market price for the item bro...
Bro,
Care to share where can i mod my stock halogen to projector HID for RM700?
Thanks in advance.
rwd;814228 said:
Changed both belt Tensioner of mine E46 M43B19 during the last weekend...resolved the annoying squeaky sound :)
Part = RM185 x 2
Labor = RM80
RM1.6k for everything inclusive (ie. holder, wiring, levelling motor/sensor etc.) I would say it's a good buy. I was quoted around RM2.5k the last I asked.
However, I would say the light throw of the original Xenon is not impressive. An upgrade to FX-R projectors like what bro aidilj would yield good results.
Replaced front passenger side power window switch today. Bought new from BA. DIY install based on instruction video on YouTube.
- Window lifter switch, passenger (61316902179) - RM180
Chop shops are selling RM100-120
Latest repair works
Rear Wheel Bearing - RM110 (pair)
Labour - RM150
Front Wheel Bearing - RM600 (Pair)
Labour - RM80
A/c Filter - RM150
Gearbox Bracket - RM280
Gearbox Mounting - 2xRM65
Labour - RM80
The rear wheel bearing is done earlier, quite surprised to see the difference in the price for front n rear... But both are not similar, maybe that s why.. Now no more annoying sound from the wheel.
Latest visit to the mech @ Jln Ipoh today:
- 1 x Flywheel oil seal (Brand is Elring, teflon with spring type) = RM85
- 1 x Torque converter oil seal = RM75
- 2 x O-rings = RM20
- 2 x ZA Lifeguard5 = RM42 per 1L bottle
- 7 x ZF Lifeguard5 = RM39 per 1L bottle (Suan Huat, Tmn Paramount)
- 1 x ATF filter (Brand: Filtran) = RM33 (Bavarian Auto)
- 1 x ATF sump gasket = RM30 (Bavarian Auto)
- 1 x BMW oil filter = RM35 (Bavarian Auto)
- 2 x Shell Helix Ultra = RM99 per 4L bottle (Tesco)
- Labor for replacement of flywheel oil seal, TC oil seal, engine oil and ATF change = RM250
TOTAL = RM1083
TOTAL = RM1083
Bro Wingzee, so no more leaking, solved d? seems like a good deal there, the pricing (labor) looks reasonable, considering the works needed.
Hi bro, gotta run in few days and monitor first. Hopefully it solves the problem. Normally the original oil seal should last about 80-100k km if the job is done properly.
i think my repair will cost more, coz almost all 'leakable' parts are leaking.lol. my engine is leaking at the top gasket as well..
Valve cover gasket you mean? OEM German brands like Victor Reinz, Febi or Elring Klinger is only about RM100++ (can't remember the exact number). It's the labor which may cost more.
Yea, i guess so. I even got quoted for top overhaul, but it costs a lot..would definitely consider a top overhaul if the cost is comparable...
TOTAL = RM1083
Bro wingzee, what's the spec for the shell oil?is it fully synthetic.cheers...
Hi bro, it's 5W-40. Made in EU. Without any seal on top over unlike local-made ones.
Was quoted RM262 per side for front brake rotors from BA. Original BMW (non-OEM).
Bought the Lower Engine Cover from Stutgart.Part Number: 5171 8242 567....RM430 (ori)...
The clip is RM8 per piece.
Please be careful with the part number. Make sure it is appropiate to your ride. I almost hit a big problem at first.
Sharing is caring :)
wingzee;816617 said:
Prices quoted by Bavarian Auto:
E46 side signal indicators (fender) - RM48 each (OEM Germany brand: FER, White color)
Engine mounting (M54) - RM97 each (OEM Germany brand: Corteco) | Reference: http://www.e46fanatics.com/forum/showthread.php?p=11383101 OR http://forum.e46fanatics.com/showthread.php?t=972712&page=2 (Corteco is listed as more expensive as compared to Sach-Boge/Lemforder AND is the OEM brand for E46 M3 mounts)
Gearbox mounting (5HP19) - RM27 each (OEM Germany brand: Lemforder)
Bro Wingzee,
The Gearbox mounting, is it the two rubbers that hold the gearbox, screwed to the gearbox bracket? I got mine for rm65 each, if it s the same thing, then it s not good for me, and need to reconsider my parts source. Hope it s different thing.
azeL_Inc;816627 said:
Bro Wingzee,
Hi bro azeL, that should be the gearbox mounting. It looks like this:
Part #2 (P/N 22316799331)
