E46 Part and Service Cost II
Sent my car to Albert Fang to have a look at the bump steer issue. He replaced my steering column and it has reduced the effect of the bump steer significantly. Costs RM650.00. This guy is really good and professional.
Btw, according to him, the steering rack for 330 is diffferent from the rest. is that true? any idea? cause a check with realoem seems to show the same part number for all the e46 models.
Good to know that the bump-steer is fixed/reduced significantly. I would trust realoem more, they tend to say like that to charge more? If its different and costs less then we'll be happy.
Anyway, changed the wheel speed/abs sensor at ZF auto for RM265. I think I saw somebody changed it for less (RM230) but I'm not complaining..
sir.. cost to buy lifted (power windor) only RM170. if u open YOUTUBE and type DIY E46 POWER WINDOW. I think u can replace that. i haved do that..
Invoice of my overhauled n42b20 engine in february 2012
xcrave;725768 said:
*above* Whoa... can buy a new halfcut that may need lesser job than that...
The cost of halfcut and labor will be more than that I think. Oso halfcut is still a used engine and need to replace wear items.
Sumore it will need to go engine no conversion. Even if rebuilding or overhaul engine is higher I will still go for it. At least peace of mind
and you will get the performance and feel of new engine. Better in long run.
23.3.2012
Total labour: RM 315 (fabrication service, to replace front & rear absorbers, to replace pressure something + gasket + oil level sensor)
Oil filter RM 45
Engine Oil RM 135 (semi syn)
Absorbers 1 set (front and rear) RM 900
Absorber mounting (front & rear) 4 pcs RM 240
Damper 4 pcs RM 160
Linkage 2 pcs RM 170
Oil pessure switch RM 55
Oil cap RM 75
Oil level sensor RM 280
Control arm bush RM 300
alignment RM 35
Car wash RM 16
plus 6% service tax
Hi bro,
Can PM me where you got that done? Looks professionally done and the charges seem reasonable since so many things were done for only RM9976. How's the car after the overhaul bro?
I've changed my engine to second hand from Japan at MSpeed on Dec at around RM9500 all inclusive....
Dear All, Greetings!
I'm new to this club, hope I'm welcomed by each and every one of you here.
I would like to request for favour on advise due to my E46 Lifestyle 318i having problems with its engine oil consumptions.
The engine oils warning pops up (orange) even before I hit 5,000KM and my recent consultation with a mechanic in subang jaya
gave me headspin.
It is believed the problem is due to the engine seals and they are advising me to overhaul the engine.
They cant give me an exact budget as they said, it could only be determined once the engine is opened.
The cost as they advise will be roughly MYR 7,000 for top overhaul and MYR 15,000 for a complete overhaul if it is necessary.
I was also told that the engine has been replaced,
I was not aware of this until i double confirmed it on the grant, that i believe was an act of foolish of me for not checking when i bought the car.
I hope all of you would be able to share some insights and guidance to help me...
Thank You, Sunil
Hi All...
Would like to share my recent spending on maintenance.
E46 318i Lifestyle 2.0
Parts Replacement:
Front brake pad RM 310.00
Front brake disc RM 380.00
Rear brake pad RM 230.00
Rear brake disc R 350.00
Brake fluid dot 4 RM 30.00
Lower arm front RM 1360.00
Lower arm bush RM 382.00
Brake sensor RM 136.00
Absorber front RM 900.00
Absorber mtg front RM210.00
Absorber damper front RM 70.00
Absorber cover front RM 60.00
Absorber rear RM 480.00
Absorber mtg rear RM 90.00
Absorber damper rear RM 70.00
Absorber cover rear RM 30.00
Workmanship:
To replace front and rear brake pad +
To replace front and rear brake disc RM 90.00
To replace front lower arm RM 60.00
To replace absorber front + rear, mtg, damper, cover assy. RM 120.00
Total RM 5371.50 (aft tax)
Maintenance Cont'
Parts Replacement:
Oil sum nut RM 30.00
Expention tank RM 450.00
Bottom hose RM 185.00
Bottom hose switch 120.00
Upper hose RM 276.00
Radiator by pass hose RM 410.00
Thernostat bottom RM 249.00
Torque convertor oil seal RM 145.00
Fly wheel oil seal RM 70.00
Timing oil seal RM 90.00
Oil filter housing gasket RM 72.00
Engine oil sum gasket RM 110.00
Engine lipstick o'ring RM 6.00
Valve cover gasket RM 275.00
Oil level sensor RM 286.00
p/strg fluid RM 50.00
p/strg hose (tank pump) RM 224.00
p/strg hose (tank oil cooler) RM 285.00
p/strg tank RM 110.00
Engine mounting RM 500.00
Gear box mounting RM 120.00
Air filter 95.00
Wiper blade RM 180.00
Long shaft mounting RM 185.00
Long shaft oil seal RM 110.00
Gear lever oil seal RM 33.00
A/T gasket RM 140.00
A/T Filter RM 120.00
Degreaser RM 10.00
Tank plate cover RM 45.00
Oil filter RM 100.00
Vent valve RM 210.00
VSI fully engine oil - 5L RM 262.50
Radiator coolant RM 50.00
A/T fluid 5 RM 600.00
Universal joint RM 150.00
Tyres:
Michelin Pilot Sport PS3 255/35R18 x 2 RM 2100.00
Tyre valve RM 12.00
Wheel balancing RM 60.00
wheel alignment front & rear RM 180.00
Workmanship:
Oil change services RM 30.00
Remove and install gear box assy
Replace fly wheel oil seal, torque convertor oil seal, gear box mtg
Replace A/T fluid, filter, gasket, gear level oil seal RM 350.00
Replace engine mounting RM 120.00
Remove and install oil sum gasket, oil lever sensor, timing oil seal RM 200.00
Replace p/strg hose and tank RM 80.00
Replace expention tank, bottom hose, upper hose, by pass hose & thermostat RM 120.00
Clean up engine compartment RM 15.00
Replace valve cover gasket RM 60.00
Total RM 9994.00 (aft tax)
but after all this .. now their telling me to overhaul the engine >> estimated to be RM 15,000.00
Please advise on what i should do..
Will appreciate.
Petrol RM 100.00
Sunilram,
You better run fast and seek another BMW specialist workshop opinion. The prices that you were charged were on the very high side.
Sunilram for the total $$ you're paying and asked to pay you can get another used UDM already! Better seek 2nd opinions from other workshops!!
Hi all..
kaiserrand, Herbert, seewai, azeL_Inc...
thank you for the sincere opinions..
can you please advise a workshop for me?
Bro, please search in the forum. There're several threads discussing workshops forummers go, and their locations too.
Cheers.
sunilram;728709 said:
Hi all..
Hi seewai,
greetings!
i hear alot being mentioned about mspeed and autobahn... do u go to any one these? do provide some guidance..
thank you..
