E46 Part and Service Cost II
Azel,
The front ones are the engine mountings and price is RM 180 for 2 pieces. Symptom of bad engine mounting is vibration when engine is idling.
Herbert;761147 said:
Azel,
hurm...that s weird..i guess i need to find second opinion then.....shud have note down what s the part's name that cost me rm400, but i m sure he didnt mentioned anything on engine mounting...
i did noticed the vibration when stopping at traffic light, but couldnt care less.. haha..the reason i m doing it becoz if i jack up the car, i can see that the gearbox almost fall from it place, the screw that holding the gearbox is almost at the end of it place (it s a type of screw that can allow the gearbox to move forward n back (hard to explain, haha). basically, gearbox is shifted to the end of the car, it supposed to be a bit ke depan. scare the gearbox fall down when i m driving, LOL. imagining that makes me want to repair it now!
anyway, thx a bunch Herbert! gonna go for second opinion today n will post back!
Azel are you talking about the item 4
If that was the item(Engine Mounting), it will cost you RM180 for 2pcs from BA. Btw hv pm you about the lower arm info
Update for my 330ci Msport
Part1
Use left/right engine mounting Rm80
Use front left Msport lower arm RM120
Use oem Speaker set front & rear RM150
Use 2pcs O2 sensor before catalic converter Rm300
New O2 sensor socket tool RM40
New fuel filter came with valve Rm120
New rear left wheel bearing Rm150 (330i rear wheel bearing bigger than other model e46)
Labour to pump bearing Rm30
Part1
Pasang sendiri ka?
Half half with my formen bro... ikut kan my formen tak nak buat kete aku dia suruh buat sendiri
5 sept 2012
Rebuilt L/R driveshaft (CV joint) RM300
Labour rm120
Repair 1 rim RM60
Labour + balancing RM28
Guys,
I just repaired my e46 year 2000. Please guide me if the pricing quoted is reasonable. Done by Levin Auto at SP.
1) Front Absorber Assy - 2 pcs 910
2) Front Absorber damper - 2 pcs 100
3) Front Lower arm - 2 pcs 1300
4) Engine Mounting - 2 pcs 440
5) Gearbox Mounting - 2 pcs 200
6) Lower arm bush - 2 pcs 400
7) Front absorber dust cover - 2 pcs 50
8) Pump Bush - 2 pcs 20
9) Water Pump - 1 pcs 195
10) Belt tensioner bearing - 3 pcs 255
11) Engine Oil Toyo 8000 full syn - 1 bottle 198
12) oil filter - 1 pcs 45
13) Reset computer/scan - 80
14) Labor Charge - 480
All at RM 4682. Is this fair price. All Europe brand forgotten the name start with L from automart. Thx guys
vramakr;773693 said:
Guys,
I presumed urs is the 1.9 lit engine...the mountings seems to be on the high side IMHO...
Anyone can help me get this item from a cheaper source (than quoted below) and post over to me in KK?
Valve Cover Gasket Set - 11129070990 - RM135 (Ori), RM110 (OEM)
12-Pieces Grommets (Head Nut Grommets)- 11127838077 - NO-stock
(Vanos) Gasket Steel - 11361433817 RM22 (ORI)
Oil Filter - RM40 (ORI), RM28 (OEM)
NGK Spark Plugs x 6 - RM18 each (no NGK this is BOSCH) - BKR6EQUP??
Serpentine Belt : 11281706545
AC Belt : 11281437450
Rim lugs x2pcs (rim nut lost when changing rim aiyo..)
Windscreen washer pump 323 325 328 330 1541
I think most of the prices above are pretty reasonable already, maybe just like few RM difference.
Hi folks
My 330 steering wheel lost it's power steering suddenly. According to the mech, it's the steering pump that has failed and quoted me 1200 for a new pump and 600 for a used one.
Any idea if that's a fair estimate? Many thanks
556129;787074 said:
Hi folks
Last year I bought my new power steering pump for RM 850 (original LUK brand) from Bomin Auto, Jalan Ipoh, KL. Please also replace the power steering oil reservior cum filter (RM 60.00) and remember to do a complete flush of the power steering system.
Pls giv comment about the price I just change,
1. Deflect pulley = RM150
2. Belt tensioner assy = RM250
3. Alternator assy = RM1200
4. Top hose = RM250
Labour = RM100
Changed my ATF
ATF LT71141- Rm 58 x 6 = Rm348.
ATF filter - Rm78
Gasket - Rm85
Labour - Rm100
Total -Rm611, discount Rm11
Grand total Rm600.
Reasonable?
2nd visit 11/12/12
Changed power steering hose (hi pressure) - rm 460
Power steering fluid - rm30
Labour -rm80
Rear absorbers+mounting+damper - rm380
Labour - rm70
Total second visit to workshop - rm970
Strider74;789513 said:
2nd visit 11/12/12
Labour -rm80
Labour - rm20
Care to share where your workshop
