E46 Part and Service Cost II
Serviced my 318I (2001) at BM Auto. Normal oil service.
Petronas syntium = RM198
Engine flush = RM 60 (apparently it is their std service)
Oil Filter = RM43.5 (I think a little on the high side, paid RM30 last year in another shop)
washer liquid = RM6.3
Microfilter = RM175.5 (i think cheaper from the spare part shop)
service (no modic) = RM 38
Total = RM522.9
the mechanic there tried to convince me accept using vacuum to suck out the engine oil instead of actually draining thro the drain plug. But i prefer good old method of draining. the internal of the oil pan is designed to slope towards the drain plug opening.
My previous oil service at FD Jaya in Old Klang Road cost me only RM346 - oil, filter, modic and nothing fancy. Maybe I will go back to old klang road for my next service.
Hi all...I need some advise from here...lately i encounter the ASC, HANDBREAK and ABS light on my dash...anyone have the fault before??? I was told the computer need to change
Any good workshop to recomend please?
My car is made 2002 facelift 318i 2.0 CKD. Do not ask me to send Auto Bavaria ...their service suck and cost a boom.
THANKS!
KURNIA Regional Insurance Clinic (8th Dec 2007)
Dear all Members & Forumers
Kurnia Insurans has proposed to organise an Insurance Clinic to help us all understand our motor policy better. This is so that we are better equipped with the knowledge and would know better about our rights as policy holders. Especially so if you have the misfortune of having an accident and involves compensation from your respective insurance providers.
Following are the details of the clinic
Date: 8/12/2007 (Saturday)
Venue: 9th Floor, Training Room,
Menara Kurnia, Bandar Sunway
Time: 4.00pm onwards
Supported by: KIMB Wilayah Branch
Reception of members arrival
Welcoming speech by
  • Mr Chow, GM Marketing
  • Mr Jeffrey Ewe, Club Vice President
Motor clinic agenda:
a)Definition of comprehensive motor insurance
b)Motor Insurance extra benefits extension
·Windscreen coverage
·Special Peril coverage
·Driver & Passengers’ PA
c)Motor Claim Procedure
·Provide basic guideline/ Workflow of Theft & Own Damage claim
·Introductory of panel workshop
·Role of adjuster
·Kurnia Express
d)KAA Assist
·Role and assistance provided
·Perks and benefit
e)Q & A session
f)Refreshment serving
To register go here: http://www.bmwclubmalaysia.com/forums/showthread.php?t=15514
thanks for the info joeylow,
will certainly keep that in mind in future.thak you for all the expert views.
thank u guys.. tried to search on previous threads..do you the best workshop to go to in KL area that can do a good job in bmw E36 repairs?
had a few things done on my bmw 316ise manual 2001 today..
oil filter housing ring and gasket ( leaking before )..= 45
granshaft oil seal = 60
water pump ( original ) , first time changed since 2001 = 450
coolant = 30
labor charge = 150
total = rm 735
any comments on this guys ..?
next due service is not due for another 5000km , shall worry financially bout that later,
just a thought , will the market price be any different compared to an auto with the same make and year ?
also , how do i apply for becoming an official member ?
working in a hospital does not allow me the luxury of time to go for tt i'm afraid.although i very much like to.
the service was done at a local garage here , recommende by fellow beemers here in muar,.
I think it's not that expensive to maintain E46. Just do the normal schedule maintainance should do. But the thing that make it expensive is because of the wear and tear thing due to our climate. If you can stand driving in a UDM that having weard sound in the cockpit or the engine .... then should be cheap for you la.....me ...better go and change the thing and drive smoothly...
Today off..
so sent my car to MSpeed
Rear brake pads 140
front & rear sensors 80
Ah Meng said my brake booster, engine mounting giving way
E46 325i SMG
Problem/symptoms:
- Clutch slipping when moving from standstill position
- Lack of 'bite' when shifting through gears
- Jerky gear change during normal driving
- Clutch slips badly when using launch control.
Brand new clutch plate - RM2150
Gearbox mounting - RM50
Labor & reprogramming - RM350
Gear shifts very smoothly after changing parts. Less jerking while normal driving. Improved shifting in Sport mode. More responsive acceleration due to improved shifting. Feels like a semi-racing clutch. Pricey, but money well spent.
Riezal-R;293892 said:
E46 325i SMG
Problem/symptoms:
Hi Riezal,
You did yours at AB?
Forumers & members,
I would to get some feedback from all of you. I'm going to send my car for servicing end of this week. How much it cost me if..............
a) Change engine oil (shell helix ultra) & oil filter (OEM)
b) ATF fluid
c) Fuel filter (If I’m not wrong) located at undercarriage
d) Labour cost
Appreciate all the sifu can provide me an estimate cost (so I can compare with the quote given by workshop)
Forumers & members,:stupid:
b) ATF fluid
d) Labour cost
:burnout:
can someone please help me?
there is a burning rubber smell when i get out of the car after driving about 15 minutes. anyone had this problem????
Cost of service
b) ATF fluid
d) Labour cost
:burnout:
If the above is the only things u are doing, should be less then RM450....
