E46 Gearbox
wlchong77
Hi all the MASTERS,My name is Chong from Ipoh , I'm actually seeking advice or has anyone encountered b4 some gearbox problem.During drive the car is perfect. For example, when you are depressing your brake from moving to stationary at the traffic light, I feel the car shivering as the idling goes low and back to normal. It comes once a while SEEKING HELP FROM MASTERS:confused:
I am not too sure, but maybe its your idle control valve... I encontered the same problem with my E36 as well... I am just guessing here, so dont take my word for it.. seek the wisdom of many guru's that live here
thanks but no idea yet so far. I've just done 57000km service on the Automatic transmission and change the ATF filter found nothing except the oil is a bit on the dark side. Hope that everything goes well
Does not seem to be a gear box issue. Car is new at 57,000km. I suggest a ATF oil change at 60,000.
Do a diagnostic check for Air Mass flow sensor.
