kimi_el;259022 said:Hi Keane
Fyi, you can try checking out on your 'air mask'.
I encountered almost the same problem as yours.
Once changed, everything back to tiptop condition!!
keane;259129 said:Hi Kimi,
what is "air mask" anyway...is it expensive? where is the best place to change it?
thanks
keane
keane;258979 said:Hi, i didn't change my gearbox .. i just change my ATF.....anyway, for ATF alone, they charge me about RM 500 to RM 600..
i think it's a pretty fair price..
thanks
keane
emaveric;259385 said:i know but was just wondering in an event of gearbox change, how much it will cost.. anyone?
keane;259439 said:well, what i heard, the worst case is about 8k...be prepared..
thanks
keane
keane;258598 said:Hi Sushi,
Thanks for sharing your experince, In facts, i also need to wait 2 to 3 mins warming up the enginer then everything is fine....good to hear it's normal..but i will keep good track on the gearbox, coz i heard from expert, the most expensive repaid for bimmer is gearbox and the repair cost can shoot up to 8k....
Oh by the way, fyi, i encouter this problem before i flush my ATF but the problem still exist after i flush my ATF....hope this is normal though.
In case, you want to flush your ATF after 8K Km, i recommend AMG at taman mayang, it's cheaper than stuart....just a recommendation...
Keep me posted once your problem subside....
thanks,
BMWowner
Sushi69;259965 said:Hi Keane,
I also did my 1st ever UDM service at AMG.. The owner is quite nice, recommended from REDZONE.. pricing as well..
Did they flush and change new atf or just changed it for u.. also did it cost $500 to $600..
tq
MRTA.chew;272519 said:keane,
i think your car is a used car that may have been abused by the previous owner. if you've done the gear exercise during morning cold starts and atf + filter change but the gear box still jerks, it means there could be some other fault component. it may be the gear switch just below the gear stick having worn off causing the contact between the gears to be lesser, or it may be some bearing or valve at the gear box itself.
you need a good mechanic who's competent with gearbox. do ask around.
keane;272574 said:Hi Chew,
that's for your reply, after so long i'm waiting for someone who can reply me. YES, i bought that as second hand and i believe that what you said the previous owner abuse the car.
So, do you have any idea where is the good place or good person who can recommend to me, and normally how much does it cost to fix that?
Most importantly, is it some sort of overhauling exercise and need to take out the whole gearbox and fix it?
please advise coz i think i need to prepare some saving for that happen.
Thanks,
keane
chaiks;272770 said:Keane,
Sorry to hear your GB problem, cos that is one thing I scared most. I had my e34 525 GM 4 speed GB overhauled b4, bcos of leaking and no history of ever serviced in the past 12 yrs. I got it done at Mspeed by Kenny (not mistaken around $5k), and been driving it without problem since I last trade it in. The mileage was 150k km, and believe can push on another 100k without problem. At least get another opinion, cos I feel overhaul with new parts is better than replacing a used unit without history.
Good luck.
Alan Teh;273046 said:Yup, i agree with u
three 18;272769 said:Bro, I just overhaul my GB. Cost me 7.8k. Took a week to accomplish. I did it cos I totally lost reverse. Since yr UDM is 2nd hand, as I mech suggested to me (he thought I got mine 2nd hand). Take yr key to AB and slot it in there machine (dunno what's it called). Apparently, that will tell u the actual mileage. Mileage on yr dash can me adjusted, but not the key. Maybe that can tell u a little more about yr car.
Ah ya... AB do charge for this service. Good luck.
