e46 erratic idling ? help ...
badmd
hi guys , been having this problem, initially car will low idle during morning start 500 rpm ,( before it was normally 700-800rpm ) doesnt die off and im able send my kids to school without problems , later when car becomes stationary at traffic light or when slow down or manually shift to ( e46 manual 2001 ) low gear , the rpm suddenly goes up to 2000-2500rpm , and my foot is nowhere near the pedal.i've done full oil service today , checked the air / oil filter , no leaking hose , changed the idle ring twice already , and still the problem persist although a little bit less than before , barely 3-4 hrs after servicing .where should i be looking at ? whats wrong ?appreciate all the help and knowledge , thanks.
Check your idle control valve unit..ask reputable mechanic to check that out..just my 2 cents
Plug in diagnostiic machine, the error is probably already logged.
^ yeah what AidilJ said... i think the scanner can zero in to the problem ...
Unless its related to non ECU/DME that one need manual inspection...
hi all , thanks for the feedback . really appreciated it . Idling problem now solved after changing the air hose and TPS sensor , no problems with the replaced idle ring as well .Unfortunately , my waterhose spare tank e46 and the head water pipe was leaking everywhere after i had fixed the idling problem , and so had to replace that too. in all my 6 yrs of having this car , this year was more physically and financially challenging ,. .. wonder if anyone has got the same experience with having almost 11 yr old car. Mine has clocked a 108000 miles or so ( still using the same unit setting from uk ).
once again tq all for the advise
Good to hear it solved bro..we will try to give opinion in any way we can to sort things out..indeed, owning a Bimmer is challenging at trying times..the rest of it? Joy...and sheer driving pleasure..
