herbert;465085 said:Mine is picture D. Spare key cannot remote open door. I tired recharging it by using the spare key with no success. where can i send it for battery replacement??
jarance;465133 said:jerman, maybe you can try your spare key for the above. I remember we did not try the above step.
My key was desyn when I was using my key in your car to demonstrate the procedure.
BMW2007;465256 said:Jarance, do u think the "RESYN" will work if it is a 2nd hand key from chop shop?
Jerman;465236 said:jarance,
Thanks for the reminder. Tried it but still does not work! Even your "open heart surgery" operation also failed to revive this key .
jarance;465299 said:Theoretically, YES!!!.. the GM5 module can be program to received 10 keys. but I haven't try it before.
I have read in other forum that uncut key bought from ebay can synchronize. (Note: ebay key are not rechargeable type)
If you buy key from chop shop, they are already precut... How you intend to make it fit your ignition???
affan66;465404 said:the keys also come in different frequencies. When you order, you need to make sure you order for the same frequency versions.
like mine it is 433.92MHz...
affan66;465407 said:it is dependent on your EWS module... I believe you need the VIN number. When I ordered mine from AB, the VIN will determine which key I need. Check if you can do so with the Online ETK.
