NKTOB
- Apr 12, 2006
- 1,624
Sign in the cluster shows the key icon + battery low.If not mistaken, read elsewhere that the CA key fobs are not rechargeable and need to get the battery change. Only prefacelift which will need to slot in, in order to start the car and it's rechargeable. Correct me if I'm wrong here.However, I failed to find any opening on my fob to indicate a place to remove cover for a battery change.Check with SA, they said just put the fob into the slot (next to start / stop button) and it'll charge itself.But the low battery icon has been showing up for the last one month even with the fob slotted in. So, con't to slot the fob or dig the fob up and look for a battery to replace!Mine is from a E90 LCI with CA. Thanx in advance.
