l8nite
- Aug 18, 2012
- 53
is that means the engine like baby to treat?JFT63;766372 said:He means we better be careful, dont play play maa.....cabutz
M50B25jarance;766276 said:M50 engine with Mpower cover.. vely the powderful.
l8nite;766373 said:is that means the engine like baby to treat?
hahaha. is that means the engine powerfull? never tried top speed but already reach 170km/h. dont have chance to get speed above that.JFT63;766375 said:Dont get me wrong, was just joking. It means u never know what is inside the engine until he smokes u..i have heard its amazing story..
l8nite;766381 said:hahaha. is that means the engine powerfull? never tried top speed but already reach 170km/h. dont have chance to get speed above that.
yeah, sure! but got to fix radiator first. and check the engine perfectly before floor the accelerator.JFT63;766383 said:Have no worries, do join us for some drives to learn to floor the accelerator...hehe...
l8nite;766369 said:i think like that. its from 1.8 to 2.5 but how come that happen? jpj not approve engine conversion more than 30% right.
but the owner claim from 2.0 to 2.5.
manual aircond, only driver and co pilot power windows.
l8nite;766387 said:yeah, sure! but got to fix radiator first. and check the engine perfectly before floor the accelerator.
this 8 and 9 september i will sent the car to bmw workshop at sunway for minor check. curios about the fc. and try to find new radiator if i cannot fix the hole.
ICEMAN 13;766364 said:DR jarance ..he needs you to answer that ? yuhooo where are you
need to dial 1-900-99-JARANCE ka ?
l8nite;766668 said:can i remove thermostat because my temp level always at half or meter. just start the car for 5 minutes then the temp already half meter. can i remove or not to do it?
oh ok. so i dont need to remove la? because i scared me to looking the temp like that. even my old mercedes not quarters meter. can europe car remove thermostat like japan car?zib;766705 said:That's normal I think.
It should be in the middle within 5mins of starting the engine. It will take perhaps more than 5 mins if the engine has not been started e.g. overnight or longer then it will take longer for the temp needle to reach the middle mark.
l8nite;766728 said:oh ok. so i dont need to remove la? because i scared me to looking the temp like that. even my old mercedes not quarters meter. can europe car remove thermostat like japan car?
because i already ask the workshop, he said not good remove thermostat for bmw because can cause overheat.
ok. i also heard about that. the car need the optimum temp for best performance. here my situation;zib;766731 said:The thermostat's main aim is to bring the engine temperature to its optimum level. I did think occasionally to remove the thermostats on my car as well (Japs and Contis) in the past.
In fact I did once years ago when I was a lot younger on my mom's KE30 (that's a 1977 Toyota corolla for the benefit of our younger forummer here) and it took the engine temperature forever to climb up to even past the C mark (not even the quarter mark yet).
Plus it came with a belt driven fan as well not a viscous-coupling fan in the E36/E39 or electric. So u can imagine how cold the engine was running even during midday. On hiway runs, it even ran cooler i.e. the needle dropped back to almost C.
And boy the car was sluggish and consumed fuel and oil as well as the engine was running cold and it wore the engine faster than it should had it reached it optimal temperature sooner.
The parts movements and frictions were far greater when it was cold hence led to the premature wear and tear. At the end the car needed a full overhaul and was sold off not long after that.
So there you go from my experience.
Cheers
it happen to me after i bought this car. thanks god i notice it near to my house so i return back, call the previous owner about that. then i notice radiator got problem. let the engine cold for a hour then topup water in radiator. very lucky that not my girl drive that car. the meter bulb also not good for me to look at the temp during night drive. so for safety, just let the car undrive until i get it at penang and change the new radiator.jarance;766740 said:BMW engine is designed to work at the 50% mark temperature (half way).
You start to get worry when it goes to 75% or 3/4 mark.
When the overheat light come on, you start to pray that you did not blow your engine.
pss..sst. Do not add COLD water to an overheated engine. Let it cool down for at least an hour before adding water.
if all failed, get a tow truck to send the car to a workshop to prevent further damage to your engine.
UGPM bro John_SmithJohn_Smith;766991 said:Get the radiator changed lah. It's minor price to pay compared to blowing the engine. PM me if you wanna workshop recommendation. I normally send my car to my mechanic at USJ.
