bbklow
- Apr 26, 2007
- 36
Hi udm lovers,Need help from sifus out there.. Its driving me crazy.I can only start the car after pressing on the petrol. If i don't press, and do normal crank, won't start at all.However, after start and pressing on the petrol, the moment i let go of the foot pedal, the engine dies off.When I 'artificially' increase the petrol, by adjusting the petrol wire on the trottle body, idling is okay. But, once i turn on the air con, idling drops a bit by, say 100 - 200 rpm. The engine won't die off, if i 'artificially' increase the petrol.Bought a brand new AFM about a year back & just changed adjuster unit (used), 2 days back. The old one has a leak. Have also sprayed the ecu & AFM connectors, but no difference.Pls advise..Thanks!:smokin:
