3) Remove the fusebox cover, and unplug the rearmost relay for easier access. Remove the ECU compartment cover, held by five size 8 bolts.
jsen said:phew, wat a day under a pokok.. thks for the help of vincent n LCP... results are hard to define, maybe due to pychological.. but i found tat its more revvy n it really pulls on mid rpm...
shit, the kling kling sounds are more obvious now.! might be the AF, ignition or engine oil prob... any input on this?
Lionel_Koh said:Hahahahah ...finally the potato chip was in .......test drive tomolo.......![]()
let ur car to run another day or two....let the ECU learn the new mapping.....![]()
So how is your potato chip ? any beter performance ?
LCP said:Putting just the chip alone does not warrant the need to change the brakes yet, the chip simply frees up a few horses at the top end and also make the car more driveable. Of course upgrading to better brake pads is always recommended, chipped or not, just no need to change to big mama discs...
jsen said:well, agreed with u CP.. kinda exaggerated if chipped need to replace brakes..! just tat feel tat, suddenly my brakes system are not as perfect as normal anymore.!![]()
jsen said:no le. my master pump still workin fine.. checked alredy..
just felt tat the brakes aint workin perfectly like it used to be..!![]()
Lionel_Koh said:Then change the brake pad ......![]()
snchin said:FYI. With the new chip, you do not have rev limiter anymore. So watch the revs closely when you tarik....good excuse to fit a shift light.hehhehe
No offense to anyone, ok?
snchin said:itu I tahu lah....just be careful when downshifting. With the ori chip, there's a rev cut. You can still rev all the way to redline. But the limiter cuts in. With this chip dont have mah. So have to be careful loh...
heheheh....
