Hi Guys,
Being the one who initiated this thread, I would just like to add my personal experience. I firstly decided on the E34 instead of the E36 as the boot on the E36 is too small for a family. After that, I was contemplating whether to get a 525 or a 520. After searching around the forums I was convinced that a 24v would be a better buy because:
- it is slightly newer and should have less maintenance issues.
- it is more fuel efficient if compared with the 12v.
- 24v 520 is nearly as powerful as the 12v 525.
- the 12v has a timing belt where the 24v is chain driven and does not require any replacement.
- 24v has hydraulic tappets which do not need to be adjusted. 12v requires constant attention or starts to sound like a proton going uphill.
- I have owned a E30 320 with the same 12v engine and was not impressed with the power. I can't imagine how the same engine can even move the E34 with all that additional weight.
After all that, I decided to get a 520 24v instead of a 525 24v as I was not interested in power and didn't want to pay the extra for the road tax. (Even if the 525 is slightly more fuel efficient it would not offset the extra $$$ you have to pay for the road tax AND insurance.)
So I went ahead and bought a 1993 520 24v (A). As it was a 14 year old car, I was already prepared to spend some extra $$$ to fix whatever that needed fixing. So far I have spent around $3.5k. As part of regular servicing I have changed engine oil to fully synthetic, oil filter, air filter, Redline rear diff oil, ATF, BMW coolant and numerous bulbs. Also replaced wipers, faulty air flow meter, all hoses, blocked off the heater, changed leaking radiator with a new radiator (they tend to leak around the air bleed screw), broken fuel flap hinge, rubber exhaust bracket, repaired wiring for faulty fog light switch (quite prone to fail in BMW's), and rear boot lid lights as they were leaking into the boot.
Auto gearbox is a bit suspect but I've just changed the ATF (no, the auto didn't die after that. In fact, shifts seem smoother and more power) so will see if anything else develops. Already getting the $$$ ready in case need to replace auto gearbox just in case. No issue with engine after changing AFM. Now smooth all the time. Before that idle sometimes a bit erratic.
Have also spent hundreds on Meguiar's car detailing products after being racun by this forum and the kevster.
My car came with a new coat of white paint and looks great so got motivation to keep it that way. The interior is also great as the previous owner had covered it with tan leather so no complaints there. Interior also very comfortable and spacious. Even has rear air con vents!
Car also came with 16" sport rims which look good enough for me so no need to change also.
As for driving impressions, if you are a speed junkie and feel the need for speed then you would be better off with a 525. The 520 accelerates errrr... gradually. BUT when you get to highway speed its great. Acceleration at that speed is decent and high speed cruising is excellent. Ride comfort is also great but I think the suspension bushings will need to be replaced sometime in the future (sigh.... more $$$).
Fuel economy is decent (since my former car was a 2 liter turbo I suppose anything after that is decent
). I get around 11.5l/100km on average or around 435km/$100. First time pumping the tank after buying the car cost $145!!!! Nearly fainted. After that, refueling when the warning light is fully lit cost around $135 and I get aprox 585km. I drive a mix of highway and city driving as I commute from USJ to KL daily but don't get caught in too many jams.
All in all, very happy with the car. No regrets and would still buy a 520 if the opportunity came again. If I had the cash I would buy another for the wife.
Just my 2 cents. Hope this helps.
