well well i tweaked it.though the stock e30 drum brakes are mechanically adjusted automatically,there is quite a lot more that can be done by turning the thumbwheel.i turned it 10 clicks and made the shoes to just graze the hub.gave the car a few hard braking spree.after that the pedal travel felt very much better by 50%! :yahoo: tho the braking effort remianed the same :angry:Originally posted by moots@Jan 20 2006, 01:08 PM
My stock e30(front ventilated/rear drum) has the following issues:
1. longer pedal travel than normal(compared to my
e34,saga,satria etc)
2. slightly harder foot pressure to stop the car
other than that it's ok.can stop during emergency brakes and have enough bite.i'll probably tweak the rear brake to closer tolerance this weekend
before you go for the bigger brake booster do a rear disc conversion.Originally posted by tyke@Jan 23 2006, 01:54 PM
dudes,since many of u recommend an upgrade of e30 servo to tht from an e38.....how much and where do u recommend getting it done?
many thx and rgds,
-brad-
Then what is the purpose of replace an E32/E38 brake booster into e30 ??Originally posted by Zoggee@Jan 20 2006, 07:45 PM
I can only says that the original brake is good enuf. :nyehehe:
Upgrading the master cylinder/servo is more than just pedal feel. The actual brake force will have been increased. As mentioned by Jules, this may be dangerous for some as the increased force may cause the brakes to lock easily. Of course Uncle Jules being a master karter can modulate the brakes Michael S. style!Originally posted by E28driver@Jan 25 2006, 10:10 AM
Improved pedal feel.
Originally posted by KiNaKa+Jan 25 2006, 02:11 AM-->QUOTE (KiNaKa @ Jan 25 2006, 02:11 AM)
good for stock engine maybe....this one i dunnoOriginally posted by Jules@Apr 5 2006, 09:00 PM
no-lah, someone "lectured" me that stock e30 is good! I ran a poll before on this and in addition, offered the solution.....w pictures. wanted to share but got hantam instead.....
do a search for ur answer! Fab, it was apparently off a E38.
cheers.
